Developing a peripheral which supports multiple connections.
It's a pain to have to use loads of devices as centrals - is it possible for nRF Connect (Android) to make multiple connections to one peripheral ?
1. The is a limitation by the OS (both Android and iOS), it does not allow more than one physical connection to the same peer.
2. It is not intended (or at least not designed or tested) to handle more than one physical connection to the same peer no.
Also see the Update I wrote on my previous reply.
OK thanks.
Perhaps I could make a feature request that the desktop version should support multiple connections to the same peer ?
Another workaround could be to start multiple instances of the nRF Connect for Desktop BLE app, although admittedly that would require one Dongle or DK for each instance.
I have registered a feature request for supporting multiple concurrent connections to the same peripheral.
Terje
I only have 1 dongle at the moment, so can't try that one - but it would be cheaper than buying more phones/tablets!
Do you happen to know whether a Raspberry Pi allows multiple connections to 1 peripheral ?
I am afraid I do not know if Raspberry Pi allows multiple connections to 1 peripheral. I would think it depends on what stack you run on the RPi.
Please note the implications of testing multiple connections as peripheral to multiple centrals (on different devices) versus testing against multiple central instances on one device. Most notably, when connected to different centrals the connection events will sometimes overlap (due to clock drift on the centrals), while for multiple connections to the same central all connections run on the same clock and are scheduled not to overlap (to the extent permitted by connection parameters) by the central.
Terje
