Communication lost with Zigbee
Hi to everybody,
I'm developing over nRF5 SDK v. 3.2.0 a Zigbee node in router role. In my network I've four of my nodes plus several commercial led light driver and a coordinator.
After random amount of time (from one day, to one week) some of my nodes lost communication with coordinator and never come back to communicate, the only way to recover is reboot. (rejoin is not needed).
I attach the sniffer traces, so you can see what happens; unfortunately I can't caught the exact moment in which the issue start because the long time observation period.
trace1 trace2
You have to set this preconfigured key in Wireshark in order to view the trace: 48:35:70:4b:7c:60:63:f1:4f:89:66:f5:04:65:ed:7d
In order to understand the issue I provide to you my devices long and short addresses:
F4:CE:36:53:37:52:8C:10 CBB2 Currently working
F4:CE:36:31:19:B7:A3:25 5F7A Connection lost
F4:CE:36:84:13:85:21:71 BCBC Connection lost
F4:CE:36:8C:78:03:53:9D 30A9 Connection lost
As you can see there are several messages from my devices, so these nodes are not unjoined, but the coordinator ignore every message from them, even "Device Announcement" messages.
Affected nodes only send this kinds of messages: "Network address request", "Link status", "Device Announcement", "Route request".
I can't understand the status that these nodes assumes, it seems that they lose the routing table.
  • Hi Marjeris,
    Just to update you here. I am waiting for some input from R&D for ideas on how to proceed here, but as I see it it looks like it would be difficult for us to recreate the issue when so many third party devices are involved.
    thank you.
    I was thinking, what happens if the affected nodes are in proximity of the coordinator? Does the coordinator reply to the route request of the affected nodes then?
    affected nodes are already in direct communication with coordinator. Traces attached to the case was sniffed at approximately 2 meters from coordinator.
    Maurizio
  • Hi Maurizio,
    OK, thanks for the clarification.
    After consulting with R&D this is what they propose:
    They would like you to experiment and try to figure out the smallest network size when this occurs. This is important to reduce the size of information we need to investigate the matter further.
    While doing so you should:
    • Instrument the network with a sniffer that perform traffic capture continuously.
    • Take ZBOSS trace logs from nodes in question so that we can decode logs.
    This page should cover on how to implement ZBOSS debug tracing: https://infocenter.nordicsemi.com/index.jsp?topic=%2Fsdk_tz_v4.1.0%2Fzigbee_prog_principles.html&cp=7_3_3_3&anchor=zigbee_debugging
    I am sorry this has taken so long to figure out, but you see without more information we are a bit in the darkness here, specially when this is a larger network and the issue is not occuring with only ZBOSS devices.
    Marjeris
  • Hi Marjeris,
    We are already working to do this
    This is not a problem for the network we are making.
    This is a little bit difficult for me because I've no experience with logger module and also our test network is physically in another location managed to the customer.
    BR,
    Maurizio
  • Hi Maurizio,
    For enabling ZBOSS logging there are only a few changes you need to do in sdk_config.h:
    • Set ZIGBEE_TRACE_LEVEL to 4 (debug)
    • Set ZIGBEE_TRACE_MASK to the value which track all subsystems (TRACE_SUBSYSTEM_ZCL| TRACE_SUBSYSTEM_ZDO|TRACE_SUBSYSTEM_NWK) which will be 0x0058.
    The log output would look quite cryptic, but can be decoded by our Zigbee developers.
    If the network is in another location, the best thing would be if you can try to recreate the issue with a minimal setup at your end using a DK and collect the log output from the DK.
    What I mean is that for debugging purpuses you should set a continuous traffic capture of the network together with the ZBOSS trace logs. Not to implement the sniffer as a part of your network.
    Marjeris
