[nRF52840 SDK 16.0.0] ble beacon example change TX power level
Hi all,
I'm using the "ble_beacon_app" example from the SDK 16.0.0 with the nRF52840 DK. I would like to change the TX power level.
In main.c function, I tried to change the advertising_init() by adding the following code:
    int8_t tx_power_level = 8;
    advdata.p_tx_power_level = &tx_power_level;
I get no error by compiling the project, but the application doesn't work and I cannot see any device from the nRF connect App scanner.
Could you please help me where is the problem? Thank you in advance
  • Today I also tried to update the parameters m_adv_params of ble_gap_adv_params_t data type, which is declared at the beginning of main.c, by adding in advertising_init() function the last line of the following code:
        m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
        m_adv_params.p_peer_addr     = NULL;    // Undirected advertisement.
        m_adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
        m_adv_params.interval        = NON_CONNECTABLE_ADV_INTERVAL;
        m_adv_params.duration        = 0;       // Never time out.
        m_adv_params.primary_phy     = BLE_GAP_PHY_CODED; // added this line,
                                                         // trying to set phy to 125 kbps
    But, even in this case, the application doesn't work. By building and debugging, the app_error_fault_heandler is called.
  • Please post new questions in a new thread. We want to make the threads follow the topic of the subject, to make information more searchable. Note that many others have asked about long-range advertising before. You should find some examples and suggestions if you use the search-function.
