how to enable readback protection
Hi, Guys,
I am trying to enable the readback protection for the code region 0 and code region 1, I know that the NRF_UICR->RBPCONF register is flash_backed, so I have to include uicr_config.h file and uncomment the line
const uint32_t UICR_RBPCONF attribute((at(0x10001004))) attribute((used)) = 0xFFFF0000;
However, I use eclipse and gcc, so it seems the "at" keyword doesn't apply in eclipse gcc, so is there any equivalence in gcc or how should I enable this readback protection in the application but not using nrfgo, I know that the nrfgo can definitely do that. Thank you:)
  • There should be no different between on the way to write to UICR. Could you try the example on github and check if the uicrBootStartAddress is written ? Which program you used to flash the chip ?
  • Hi, Hung,
    I use jlink to debug the board, so it should be J flash I think. After I add the following code to the ld file. it works.
    UICR (rw) : ORIGIN = 0x10001000, LENGTH = 0x0fd /* 0x10001000 ~ 0x100010fd-1 / .uicrrbpconf 0x10001004 : { KEEP((.uicrrbpconf)) } > UICR However, this takes much more time to compile. Do you have any crew what's going on?
  • @nimalhuang: Could you send me a sample hex file that you added section(".uicrrbpconf") the same way as I suggested ? And also another sample hex file that you use your configuration ?
    I tested here and seeing no problem. Attached in the answer above is the project and hex file I compiled with address 0x10001004 is set = 0xffff0000.
  • Hi, Hung, Thank you for your reply. I have figure out the problem. But without this line of code: KEEP((.uicrrbpconf) so is there any difference between have and havn't this line of code? Thank you
  • I ended up putting quite a bit of stuff in UICR (128 bytes of user data and 512 bytes of crypto keys).
    I have 2 sections, .infoUICR and .keysUICR, each contains a single structure (otherwise ld might swap the order)
    xxxUICR.c:
    xxxInfoUICR_t xxxInfoUICR __attribute__((section(".infoUICR"), used));
    xxxKeysUICR_t xxxKeysUICR __attribute__((section(".keysUICR"), used));
    xxx.ld:
    MEMORY
            /* manufacturing time data (customer UICR region) */
            UICR (r)          : ORIGIN = 0x10001000, LENGTH = 0x080 /* 128 bytes */
            INFO_UICR (r)     : ORIGIN = 0x10001080, LENGTH = 0x180 /* 384 bytes */
            KEYS_UICR (r)     : ORIGIN = 0x10001200, LENGTH = 0x200 /* 512 bytes */
    SECTIONS
            /* UICR info data (manufacturing time data) */
            .infoUICR (NOLOAD) :
                    KEEP(*(.infoUICR))
            } > INFO_UICR
            /* UICR key data (manufacturing time data) */
            .keysUICR (NOLOAD) :
                    KEEP(*(.keysUICR))
            } > KEYS_UICR
    I ended up writing a host C program to build up the UICR data because I have several CRC values in the various data blocks. I also did not want the UICR data embedded in the bootloader hex file so the bootloader image for the factor and the bootloader image for DFU are exactly the same.
    The host tool builds up the 1024 byte UICR page writes it to stdout as binary data which is converted to a hex file with bin2hex.py. The hex file I send the factory is a hexmerge.py of the softdevice, application, bootloader and uicr hex files.
