Current solution to update packets while advertising for every packet
I have seen this post, but it is quite old, so I would like to know what is the current solution to
  • update advertising packets while advertising, without stop and start again the transmission
  • update some bytes in my manufacturer data
  • update my packet for each new packet that i send.
I am currently using the ble_advertising library, with a NRF52 BLE kit on Eclipse.
  • Yes, my mistake. I was checking the source code of the SDK v.16, I see now that you must call encode before calling the SDK v.15.2 advdata_update version, my apologies for any confusion this might have caused.
    Don'tworry, all was clear.
    For this you will need radio notifications, for further detail on this please see my colleagues reply to this ticket.
    I have checked it, but we do not need to call sd_radio_notification_cfg_set function anymore, it is called in the ble_radio_notification_init function.
    It seems that it is working, but with my sniffers, I do not have all the frames, I miss some of them. I would like to check if it is because my sniffers cannot have all of them, or if it is because i do not send all of them. Do you have an idea how I can check which frames do I send ?
    I am happy to hear that!
    Yes, this could be the case - that the sniffer is missing some that the central is receiving, and vice verse.
    To check that the amount of frames sent, you could add a counter that increments for each advertisement - and then match this against what you would have expected/what you received on your central's end.
    If you would like to see the frames sent in particular, you could use deferred logging to do the processing post-sending, I.e sending a certain amount of frames while logging their contents - then processing the deferred logs once a certain amount has been sent.
    Would this be along the lines you were thinking?
    Karl
