A-GPS using SUPL doesn't work
DK: v0.9.0
nrf: v1.2.0
supl fw: v0.5.2
modem fw: v1.2.0
OS: Windows10
I'm trying to use assited GPS in "gps" sample program, but it doesn't work. This is log. There is no comments about SUPL.
*** Booting Zephyr OS build v2.1.99-ncs1  ***
Staring GPS application
Socket created
Getting GPS data...
Tracking: 0 Using: 0 Unhealthy: 0
Seconds since last fix 0
Scanning [|] Tracking: 0 Using: 0 Unhealthy: 0
Scanning [/] Tracking: 0 Using: 0 Unhealthy: 0
Seconds since last fix 1
Scanning [-] Tracking: 0 Using: 0 Unhealthy: 0
Scanning [\] Tracking: 0 Using: 0 Unhealthy: 0
Seconds since last fix 2
Seconds since last fix 3
Seconds since last fix 4
Seconds since last fix 5
Scanning [\]
prj.conf
CONFIG_BSD_LIBRARY=y
CONFIG_STDOUT_CONSOLE=y
CONFIG_NEWLIB_LIBC=y
CONFIG_AT_CMD=y
CONFIG_AT_NOTIF=y
# Enable SUPL client support
CONFIG_SUPL_CLIENT_LIB=y # Set y
# Networking
CONFIG_NETWORKING=y
CONFIG_NET_SOCKETS_OFFLOAD=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_NET_SOCKETS_SOCKOPT_TLS=y
# Disable native network stack to save some memory
CONFIG_NET_NATIVE=n
# Main thread
CONFIG_HEAP_MEM_POOL_SIZE=2048
CONFIG_MAIN_STACK_SIZE=4096
In main.c,
supl_init function is executed successfully.
gps_data->data_id value is always 1 or 2 and it isn't set 3.
Any help?
  • >I think that your west is out-dated. Could you try "pip3 install west --upgrade" and see if it starts working?
    This works out! Thank you so much!
    I tried AGPS with iBasis SIM and got this error.
    New AGPS data requested, contacting SUPL server, flags 59
    Established LTE link
    ip adc2:4cc0:: (c04cc2ad) port 7276
    Starting SUPL session
    ULP encoding length: 38
    Bytes sent: 38
    Bytes received: 34
    ULP ossDecode success, choice 3
    SUPL server responded using version 2.0.4
    SUPL response received
    ULP encoding length: 57
    Bytes sent: 57
    Bytes received: 708
    ULP ossDecode more input 4
    Bytes received: 1416
    Bytes received: 2124
    Bytes received: 2832
    Bytes received: 3067
    ULP ossDecode success, choice 5
    Injected AGPS data, flags: 1, size: 16
    Injected AGPS data, flags: 2, size: 72
    Injected AGPS data, flags: 3, size: 32
    Injected AGPS data, flags: 8, size: 4
    Injected AGPS data, flags: 4, size: 8
    Injected AGPS data, flags: 6, size: 144
    No location data available
    Injected AGPS data, flags: 7, size: 16
    MCC location info injected, MCC: 440
            Lat: 4603642 Lon: 2132664
            Unc semiminor: 127
            Unc semimajor: 127
            Confidence: 90
            Orientation: 0
    SUPL POS received
    read again
    read again
    read again
    read error: -1
    ULP ossDecode fail 5
    SUPL error: 1
    ULP encoding length: 34
    Sending SUPL message failed, bytes_sent: -1
    SUPL session internal resources released
    SUPL session finished
    Done
    Also I tested the same program with another SIM. Then I got another error.
    Failed to resolve hostname supl.google.com on IPv4, errno: 0)
    Can you give me any help?
    Does it give this error every time? Are you connecting over LTE M1, or NB1?
    We have seen some stability issues when using this in combination with NB1.
    failure to resolve the hostname usually indicates that the vendor does not provide DNS. Is this over NB-IoT? If yes, can you try setting CONFIG_LTE_LEGACY_PCO_MODE=y?
    Håkon
  • I was intending to use LTE-M. This is prj.conf and there is no command related to NB-IoT or M1.
    Do I miss anything?
    CONFIG_AT_CMD=y
    CONFIG_AT_NOTIF=y
    # Networking
    CONFIG_NETWORKING=y
    CONFIG_NET_NATIVE=n
    # Main thread
    CONFIG_LTE_LOCK_BANDS=y
    CONFIG_LTE_LOCK_BAND_MASK="10000000"
  • when I append these lines, I got an error. Any tip?
    CONFIG_LTE_LINK_CONTROL=y
    CONFIG_LTE_NETWORK_MODE_LTE_M_GPS=y
    Failed to initialize modem
  • >failure to resolve the hostname usually indicates that the vendor does not provide DNS.
    This means SIM Card vendor right? I'm using MVNO SIM card
