How to add app sources on nRF Connect v3.3.1
Hi Dears:
   When I downloaded and installed nRF Connect v3.3.1, the following screen appeared.
  I remember when there was a drop-down box to select the BLE component.
  But it is not available now. How can I add app source?
  In addition, my working environment is windows10
  • Hello
    I seem to be facing a similar problem now with with version 3.8.0 as well as the latest version 3.9.3.
    I can indeed access the link https://raw.githubusercontent.com/NordicSemiconductor/pc-nrfconnect-core/master/apps.json without any DNS issues. So I tried to specify the path to this .json under SETTINGS -> App sources in the nRF Connect App. However, I still an error like this:
    JSON does not contain expected _source tag
    Its a little annoying because I used to be able to work with the nRF Connect App perfectly till yesterday, and its not working now with no explanation.
    Although there is one problem that occurred today after which the nRF Connect App is giving this trouble. When I started the nRF Connect App today it notified me of an Upgrade. I proceeded without upgrading as I wanted to try something quickly and thought of upgrading later. Before I could even open the BLE module, my system crashed with a blue screen. I was able to restart the system, but ever since then, nRF Connect is giving me this gray blank window.
    Is there anything I can do to fix this problem ?
    Thank you
    PS: My work environment is also Windows 10.
