Possible to support ZigBee and proprietary RF concurrently?
Hi, we are developing a home automation product that needs to support ZigBee. However, at the same time I would like the devices to be able to work with a simple non-mesh RF protocol in case the customer does not have an existing ZigBee coordinator. Is this possible using Nordic SoCs?
Thanks.
  • The main point is that Zigbee requires at least another ZC or ZR to be operational. In the case that a customer does not already have a Zigbee network at home, I would like to give them the choice of using the product directly from a remote control. Dynamic multiprotocol would obviously be the best as it wouldn't require the end user to do anything, but switched would be acceptable as well. In this case, I take it that it is only possible to implement multiprotocol on 802.15.4 based protocols?
  • I don't see a reason for having them running concurrently. Switching should also work without user interaction. You can leave the device running in Zigbee checking for ZC or ZR for, let's say 30 seconds and then switch back to proprietary/RF4CE in the background. What important here is that if you need to have 2 protocols running at the same time or not. If not, then you are free to switch to any protocol you like after you checked that there is no current Zigbee network in the area.
    The challenge of having 2 networks running at the same time is that it requires timeslot mechanism to switch between protocols rapidly without interrupting the communication. It's not supported natively in the ZBoss stack that we used in nRF5 SDK for Thread and Zigbee. There is support for timeslot API in Zephyr (NCS) project here: https://github.com/nrfconnect/sdk-nrfxlib/blob/master/mpsl/include/mpsl_timeslot.h
    But we haven't done any test on multiprotocol on that platform.
