I'm trying to make a one-shot MQTT publisher and I'm able to get 22 messages published but every time I try to publish the 23rd the code hangs in mqtt_transport_write in mqtt_transport.c
Here's relevant code.
Calling code (in a loop):
err = send_one_shot_mqtt_msg(MQTT_QOS_1_AT_LEAST_ONCE, nmea_strings[0], strlen(nmea_strings[0]), CONFIG_MQTT_PUB_TOPIC); if (err != 0){ printk("Error: send_one_shot_mqtt_msg: %u\n", err); return -1; } connect_count++; printk("Connected count: %d\n", connect_count);
send_on_shot_mqtt_mdg:
int8_t send_one_shot_mqtt_msg(enum mqtt_qos qos, u8_t *data, size_t len, char *topic) { int err = 0; err = mqtt_connect(&client); if (err != 0) { printk("ERROR: mqtt_connect %d\n", err); return -1; } printk("after mqtt_connect\n"); err = fds_init(&client); if (err != 0) { printk("ERROR: fds_init %d\n", err); return -1; } err = poll_and_check_rcv_data(K_SECONDS(10)); // Wait for CONNACK if (err != 0) { printk("ERROR: poll_and_check_rcv_data %d\n", err); return -1; } err = data_publish(&client, qos, data, len); if(err < 0){ printk("fail sending reset message\n"); } err = poll_and_check_rcv_data(K_SECONDS(5)); if (err != 0) { printk("ERROR: poll_and_check_rcv_data %d\n", err); return -1; } err = unsubscribe(); if (err) { printk("Could not unsubscribe MQTT client. Error: %d\n", err); return -1; } err = mqtt_disconnect(&client); if (err) { printk("Could not disconnect MQTT client. Error: %d\n", err); return -1; } return 0; }
poll_and_check_rcv_data:
int8_t poll_and_check_rcv_data(u32_t interval_msec) { int8_t err = poll(&fds, 1, interval_msec); // Check if any data comes through LTE-M. When it is waiting for an incoming data, it sleeps if (err < 0) { printk("ERROR: poll %d\n", errno); return -1; } /* Check if data is received through LTE-M */ if ((fds.revents & POLLIN) == POLLIN) { // If get data err = mqtt_input(&client); if (err < 0) { printk("ERROR: poll %d\n", errno); return -1; } } if ((fds.revents & POLLERR) == POLLERR) { printk("POLLERR\n"); return -1; } if ((fds.revents & POLLNVAL) == POLLNVAL) { printk("POLLNVAL\n"); return -1; } return 0; }
Is there something I'm missing here?
