Zigbee CLI communication failure
I am able to use the Zigbee CLI Agent and send some commands. I am using the zb-cli-wrapper python package to send commands from python. I wrote an application that configures the module as a zigbee coordinator. If it is already configured as such, that means if the zigbee stack is already running, I just connect the cli with bdb start command (so it will not create a new network). Then, when nodes join the network, I retrieve some information using simple descriptor command. Once I have all the informations about the network, I want to be able to control and monitor the nodes.
But for some reason that I don't understand, after sending some commands to the CLI, the communication stops working. I can not communicate with the CLI until I reset the module. What could be the issue? Do you think that I am sending commands too fast? Because when I send commands manually using Minicom, it never crashes or hangs.
Damien
