mqtt_simple connect to AWS
I have an AWS account and I am comfortable with the AWS IOT operation in general. I have used it in the past. I am trying to get the sample mqtt_simple to connect to AWS IOT and be able to send packets and receive packets to the nRF9160dk board.
 I am not sure how to set up mqtt_simple parameters? I have created a thing and certificates. I have named the thing "nrf-IMEI" as recommended so it has the board ID in it. All I want to do is to be able to publish a packet to a topic on my AWS account and receive a packet from a topic in my AWS account. I have done this several times in the past with other systems so I am comfortable with AWS IOT operations and formats. I just do not understand how to get mqtt_simple to publish from my board to AWS and subscribe to messages from AWS.
Is this the correct program to use. It seems like all the pieces are there I just do not know how to use them.
I appreciate any help you can give, This is an essential requirement of our production system. right now we are using the pre-production system with a modified version of asset_tracker to send sensor data to the nRF Connect site. We need to be able to send sensor data to our AWS site.
  • Martin
    yes the big problem is that V1.3.0 asset_tracker crashes. as stated earlier I get the FLIP data so I know it is talking to my AWS account then it crashes. I have printouts above. Jan made a suggestion but I did not understand it. can you help me understand how to stop V1.3.0 from crashing.
  • Hi Timothy,
    Are having issues with the asset_tracker application from v1.3.0 with the default settings?
    If so, please make sure that you have the latest modem firmware installed and that you are using the default configurations.
    Please share the serial output log when this issue happens.
  • Martin
    here is the output log. the only difference in my configuration settings is shown below to account for the AWS connection. I do not see any error indication. it just crashes. I need to get V1.3.0 working with my AWS account so I can port over the complete V1.2.0 working program that is running now 24/7.
    # MQTT
    CONFIG_MQTT_LIB=y
    CONFIG_MQTT_LIB_TLS=y
    CONFIG_AWS_IOT=y
    CONFIG_AWS_IOT_BROKER_HOST_NAME="xxxx.amazonaws.com"
    CONFIG_CLOUD_BACKEND="AWS_IOT"
    CONFIG_ASSET_TRACKER_LOG_LEVEL_DBG=y
    [00:00:00.243,774] <inf> asset_tracker: Connecting to LTE network.
    [00:00:00.250,518] <inf> asset_tracker: This may take several minutes.
    [00:00:00.257,690] <dbg> lte_lc.lte_lc_system_mode_set: Sending AT command to set system mode: AT%XSYSTEMMODE=1,0,1,0
    [00:00:00.276,702] <dbg> lte_lc.lte_lc_system_mode_set: Sending AT command to set system mode: AT%XSYSTEMMODE=1,0,1,0
    +CEREG: 2,"9E03","026B8102",7,0,0,"11100000","11100000"
    [00:00:02.185,699] <dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 2,"9E03","026B8102",7,0,0,"11100000","11100000"
    [00:00:02.197,631] <dbg> lte_lc.parse_psm_cfg: TAU: -1 sec, active time: -1 sec
    +CSCON: 1
    [00:00:02.235,412] <dbg> lte_lc.at_handler: +CSCON notification
    [00:00:05.223,632] <dbg> watchdog.secondary_feed_worker: Feeding watchdog
    +CEREG: 5,"9E03","026B8102",7,,,"11100000","11100000"
    [00:00:05.884,063] <dbg> lte_lc.at_handler: +CEREG notification: +CEREG: 5,"9E03","026B8102",7,,,"11100000","11100000"
    [00:00:05.895,812] <dbg> lte_lc.parse_psm_cfg: TAU: -1 sec, active time: -1 sec
    [00:00:05.903,930] <inf> asset_tracker: Connected to LTE network.
    [00:00:05.910,583] <inf> asset_tracker: Connecting to cloud, attempt 1 of 8
    client_id_buf my-thing
    CONFIG_AWS_IOT_BROKER_HOST_NAME a2uy3w9dvx40gv-ats.iot.us-east-1.amazonaws.com
    client_broker_init passed
    mqtt_connect passed
    aws_iot_connect 0
    [00:00:10.241,943] <inf> asset_tracker: Cloud connection request sent.
    [00:00:10.249,053] <inf> asset_tracker: Connection response timeout is set to 30 seconds.
    [00:00:10.257,873] <dbg> watchdog.secondary_feed_worker: Feeding watchdog
    [00:00:15.265,319] <dbg> watchdog.secondary_feed_worker: Feeding watchdog
    [00:00:17.252,349] <inf> aws_jobs: Subscribe: $aws/things/my-thing/jobs/notify-next
    +CSCON: 0
    [00:00:17.261,871] <dbg> lte_lc.at_handler: +CSCON notification
    [00:00:17.268,585] <inf> aws_jobs: Subscribe: $aws/things/my-thing/jobs/$next/get/#
    [00:00:17.277,465] <inf> asset_tracker: CLOUD_EVT_CONNECTED
    [00:00:17.283,569] <inf> asset_tracker: Persistent Sessions = 0
    [00:00:17.290,039] <inf> asset_tracker: CLOUD_EVT_READY
    [00:00:17.296,600] <dbg> nrf9160_gps.init: GPS socket created, fd: 1232491587
    [00:00:17.305,358] <inf> gps_control: GPS initialized
    [00:00:17.812,713] <inf> aws_fota: subscribed to notify-next topic
    [00:00:17.819,519] <inf> aws_jobs: Publish topic: $aws/things/my-thing/jobs/$next/get
    [00:00:17.827,880] <inf> aws_jobs: Publish payload {"clientToken": ""}
    +CSCON: 1
    [00:00:17.836,608] <dbg> lte_lc.at_handler: +CSCON notification
    [00:00:18.309,509] <dbg> aws_fota.on_publish_evt: Received topic: $aws/things/my-thing/jobs/$next/get/accepted
    [00:00:18.320,098] <inf> aws_fota: Checking for an available job
    [00:00:18.326,721] <dbg> aws_fota.get_job_execution: Job doc: {"clientToken":"","timestamp":1593695296}
    [00:00:18.337,005] <dbg> aws_fota.get_job_execution: Got only one field
    [00:00:18.344,177] <inf> aws_fota: No queued jobs for this device
    *** Booting Zephyr OS build v2.3.0-rc1-ncs1 ***
    [00:00:00.005,004] <inf> mcuboot: Starting bootloader
  • Please share the full prj.conf  (add it as a .zip if you have issues uploading it).
    (make sure to have CONFIG_RESET_ON_FATAL_ERROR=n)
