NRF_LOG_PUSH seems to be outputting invalid data intermittently
Hi!
I'm using the nRF52840 DK with SDK 15.2 and on Windows 10. I have been testing USB communication and while I was testing input and output data, some of the data I was outputting in the RTT viewer with NRF_LOG_INFO() was invalid. What I mean by that is that the data sent through USB into Putty is the same as the data printed with NRF_LOG_INFO():
To produce this, I used the usbd_cdc_acm_pca10056 example. Originally, this example does not print in the Viewer and I had to make some changes to the config file:
#define NRF_LOG_BACKEND_RTT_ENABLED 1
#define NRF_LOG_BACKEND_UART_ENABLED 0
I also added the following to main.c:
That weird output was generated using this:
if(m_send_flag)
    static int  frame_counter;
    size_t size = sprintf(m_tx_buffer, "Hello USB CDC FA demo: %u\r\n", frame_counter);
    NRF_LOG_INFO("%s", NRF_LOG_PUSH(m_tx_buffer));
    ret = app_usbd_cdc_acm_write(&m_app_cdc_acm, m_tx_buffer, size);
    if (ret == NRF_SUCCESS)
        ++frame_counter;
I was able to bypass the problem and get normal output when avoiding NRF_LOG_PUSH:
if(m_send_flag)
    NRF_LOG_INFO("Hello USB CDC FA demo: %u", frame_counter);
        ++frame_counter;
I find it weird to NRF_LOG_PUSH doesn't work as supposed since it is advised here.
I also tried adding NRF_LOG_FLUSH() after the call to NRF_LOG_PROCESS() but it did improve the output. I also tried adding some delay (thinking that the output would be generated to quickly for RTT Viewer) using both nrf_delay_ms() and nrf_delay_us() and it didn't do anything.
I also linked the config file used and the main source file.
 * Copyright (c) 2017 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
#include <stdint.h>
#include <stdbool.h>
#include <stddef.h>
#include <stdio.h>
#include "nrf.h"
#include "nrf_drv_usbd.h"
#include "nrf_drv_clock.h"
#include "nrf_gpio.h"
#include "nrf_delay.h"
#include "nrf_drv_power.h"
#include "app_error.h"
#include "app_util.h"
#include "app_usbd_core.h"
#include "app_usbd.h"
#include "app_usbd_string_desc.h"
#include "app_usbd_cdc_acm.h"
#include "app_usbd_serial_num.h"
#include "boards.h"
#include "bsp.h"
#include "bsp_cli.h"
#include "nrf_cli.h"
#include "nrf_cli_uart.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
 * @brief CLI interface over UART
NRF_CLI_UART_DEF(m_cli_uart_transport, 0, 64, 16);
NRF_CLI_DEF(m_cli_uart,
            "uart_cli:~$ ",
            &m_cli_uart_transport.transport,
            '\r',
            4);
/**@file
 * @defgroup usbd_cdc_acm_example main.c
 * @ingroup usbd_cdc_acm_example
 * @brief USBD CDC ACM example
#define LED_USB_RESUME      (BSP_BOARD_LED_0)
#define LED_CDC_ACM_OPEN    (BSP_BOARD_LED_1)
#define LED_CDC_ACM_RX      (BSP_BOARD_LED_2)
#define LED_CDC_ACM_TX      (BSP_BOARD_LED_3)
#define BTN_CDC_DATA_SEND       0
#define BTN_CDC_NOTIFY_SEND     1
#define BTN_CDC_DATA_KEY_RELEASE        (bsp_event_t)(BSP_EVENT_KEY_LAST + 1)
 * @brief Enable power USB detection
 * Configure if example supports USB port connection
#ifndef USBD_POWER_DETECTION
#define USBD_POWER_DETECTION true
static void cdc_acm_user_ev_handler(app_usbd_class_inst_t const * p_inst,
                                    app_usbd_cdc_acm_user_event_t event);
#define CDC_ACM_COMM_INTERFACE  0
#define CDC_ACM_COMM_EPIN       NRF_DRV_USBD_EPIN2
#define CDC_ACM_DATA_INTERFACE  1
#define CDC_ACM_DATA_EPIN       NRF_DRV_USBD_EPIN1
#define CDC_ACM_DATA_EPOUT      NRF_DRV_USBD_EPOUT1
 * @brief CDC_ACM class instance
APP_USBD_CDC_ACM_GLOBAL_DEF(m_app_cdc_acm,
                            cdc_acm_user_ev_handler,
                            CDC_ACM_COMM_INTERFACE,
                            CDC_ACM_DATA_INTERFACE,
                            CDC_ACM_COMM_EPIN,
                            CDC_ACM_DATA_EPIN,
                            CDC_ACM_DATA_EPOUT,
                            APP_USBD_CDC_COMM_PROTOCOL_AT_V250
#define READ_SIZE 1
static char m_rx_buffer[READ_SIZE];
static char m_tx_buffer[NRF_DRV_USBD_EPSIZE];
static bool m_send_flag = 0;
 * @brief User event handler @ref app_usbd_cdc_acm_user_ev_handler_t (headphones)
    app_usbd_cdc_acm_t const * p_cdc_acm = app_usbd_cdc_acm_class_get(p_inst);
    switch (event)
        case APP_USBD_CDC_ACM_USER_EVT_PORT_OPEN:
            bsp_board_led_on(LED_CDC_ACM_OPEN);
            /*Setup first transfer*/
            ret_code_t ret = app_usbd_cdc_acm_read(&m_app_cdc_acm,
                                                   m_rx_buffer,
                                                   READ_SIZE);
            UNUSED_VARIABLE(ret);
        case APP_USBD_CDC_ACM_USER_EVT_PORT_CLOSE:
            bsp_board_led_off(LED_CDC_ACM_OPEN);
        case APP_USBD_CDC_ACM_USER_EVT_TX_DONE:
            bsp_board_led_invert(LED_CDC_ACM_TX);
        case APP_USBD_CDC_ACM_USER_EVT_RX_DONE:
            ret_code_t ret;
            NRF_LOG_INFO("Bytes waiting: %d", app_usbd_cdc_acm_bytes_stored(p_cdc_acm));
            do
                /*Get amount of data transfered*/
                size_t size = app_usbd_cdc_acm_rx_size(p_cdc_acm);
                NRF_LOG_INFO("RX: size: %lu char: %c", size, m_rx_buffer[0]);
                /* Fetch data until internal buffer is empty */
                                            m_rx_buffer,
                                            READ_SIZE);
            } while (ret == NRF_SUCCESS);
            bsp_board_led_invert(LED_CDC_ACM_RX);
static void usbd_user_ev_handler(app_usbd_event_type_t event)
    switch (event)
        case APP_USBD_EVT_DRV_SUSPEND:
            bsp_board_led_off(LED_USB_RESUME);
        case APP_USBD_EVT_DRV_RESUME:
            bsp_board_led_on(LED_USB_RESUME);
        case APP_USBD_EVT_STARTED:
        case APP_USBD_EVT_STOPPED:
            app_usbd_disable();
            bsp_board_leds_off();
        case APP_USBD_EVT_POWER_DETECTED:
            NRF_LOG_INFO("USB power detected");
            if (!nrf_drv_usbd_is_enabled())
                app_usbd_enable();
        case APP_USBD_EVT_POWER_REMOVED:
            NRF_LOG_INFO("USB power removed");
            app_usbd_stop();
        case APP_USBD_EVT_POWER_READY:
            NRF_LOG_INFO("USB ready");
            app_usbd_start();
static void bsp_event_callback(bsp_event_t ev)
    ret_code_t ret;
    switch ((unsigned int)ev)
        case CONCAT_2(BSP_EVENT_KEY_, BTN_CDC_DATA_SEND):
            m_send_flag = 1;
        case BTN_CDC_DATA_KEY_RELEASE :
            m_send_flag = 0;
        case CONCAT_2(BSP_EVENT_KEY_, BTN_CDC_NOTIFY_SEND):
            ret = app_usbd_cdc_acm_serial_state_notify(&m_app_cdc_acm,
                                                       APP_USBD_CDC_ACM_SERIAL_STATE_BREAK,
                                                       false);
            return; // no implementation needed
static void init_bsp(void)
    ret_code_t ret;
    ret = bsp_init(BSP_INIT_BUTTONS, bsp_event_callback);
    APP_ERROR_CHECK(ret);
    UNUSED_RETURN_VALUE(bsp_event_to_button_action_assign(BTN_CDC_DATA_SEND,
                                                          BSP_BUTTON_ACTION_RELEASE,
                                                          BTN_CDC_DATA_KEY_RELEASE));
    /* Configure LEDs */
static void init_cli(void)
    ret_code_t ret;
    ret = bsp_cli_init(bsp_event_callback);
    nrf_drv_uart_config_t uart_config = NRF_DRV_UART_DEFAULT_CONFIG;
    uart_config.pseltxd = TX_PIN_NUMBER;
    uart_config.pselrxd = RX_PIN_NUMBER;
    uart_config.hwfc    = NRF_UART_HWFC_DISABLED;
    ret = nrf_cli_init(&m_cli_uart, &uart_config, true, true, NRF_LOG_SEVERITY_INFO);
    ret = nrf_cli_start(&m_cli_uart);
    ret_code_t ret;
    static const app_usbd_config_t usbd_config = {
        .ev_state_proc = usbd_user_ev_handler
    ret = NRF_LOG_INIT(NULL);
    ret = nrf_drv_clock_init();
    while(!nrf_drv_clock_lfclk_is_running())
        /* Just waiting */
    ret = app_timer_init();
    init_bsp();
    init_cli();
    app_usbd_serial_num_generate();
    ret = app_usbd_init(&usbd_config);
    NRF_LOG_INFO("USBD CDC ACM example started.");
    app_usbd_class_inst_t const * class_cdc_acm = app_usbd_cdc_acm_class_inst_get(&m_app_cdc_acm);
    ret = app_usbd_class_append(class_cdc_acm);
    if (USBD_POWER_DETECTION)
        ret = app_usbd_power_events_enable();
        NRF_LOG_INFO("No USB power detection enabled\r\nStarting USB now");
        app_usbd_enable();
        app_usbd_start();
    while (true)
        while (app_usbd_event_queue_process())
            /* Nothing to do */
        if(m_send_flag)
                ++frame_counter;
        nrf_delay
        nrf_cli_process(&m_cli_uart);
        UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
        NRF_LOG_FLUSH();
        /* Sleep CPU only if there was no interrupt since last loop processing */
        __WFE();
sdk_config.h
Thanks for looking into this bug!
