nRF9160 Unable to Connect to Anritsu Callbox
I sent some nRF9160 prototypes down to a CTIA certified test lab in North Carolina to do carrier TRP and TIS testing.  When they add their test sims they seem to be unable to connect to the nRF9160.  Was there anything special I needed to configure in the module for testing with a callbox?  I have the module setup to connect on bootup.  The lab inserts their sim card into the holder and applies power, booting up the module.  The module boots up and start looking for a base station, at that point the callbox the test center is using finds the device and starts to connect and initiate the test processes.  But it then fails establishing the connection.
Prior to sending the units out I tested them both with an iBasis sim and they were able to register onto Verizon’s network.
Some other info:
Anritsu 8821 callbox
Using generic test sims
Testing bands 2, 4, 12, 13
For firmware on the nRF9160, I basically took the at_client sample and modified it to call the lte_lc_init_and_connect() function.  Was there something else I missed? I attached the config file and the main.c for quick review.
Is Nordic limiting the max power at all?
#include <zephyr.h>
#include <stdio.h>
#include <drivers/uart.h>
#include <string.h>
#include <modem/lte_lc.h>
#include <modem/bsdlib.h>
/**@brief Recoverable BSD library error. */
void bsd_recoverable_error_handler(uint32_t err)
	printk("bsdlib recoverable error: %u\n", err);
/**@brief Configures modem to provide LTE link. Blocks until link is
 * successfully established.
static void modem_configure(void)
	if (IS_ENABLED(CONFIG_LTE_AUTO_INIT_AND_CONNECT)) {
		/* Do nothing, modem is already turned on and connected. */
                printk("Already Attempted Auto-Connect");
	} else {
		int err;
		printk("Establishing LTE link (this may take some time) ...\n");
		err = lte_lc_init_and_connect();
		__ASSERT(err == 0, "LTE link could not be established.");
void main(void)
	printk("The AT host sample started\n");
        modem_configure();
        printk("We're done");
# Copyright (c) 2019 Nordic Semiconductor ASA
# SPDX-License-Identifier: LicenseRef-BSD-5-Clause-Nordic
# General config
CONFIG_ASSERT=y
# Network
CONFIG_NETWORKING=y
CONFIG_NET_NATIVE=n
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_OFFLOAD=y
# BSD library
CONFIG_BSD_LIBRARY=y
# AT host library
CONFIG_AT_HOST_LIBRARY=y
# Stacks and heaps
CONFIG_MAIN_STACK_SIZE=3072
CONFIG_HEAP_MEM_POOL_SIZE=16384
# LTE link control
CONFIG_LTE_LINK_CONTROL=y
CONFIG_LTE_AUTO_INIT_AND_CONNECT=n
  • Update from IoT;
    "There are 2 options :
    1.  Try to change integrity protection from NULL to AES (for example) in tester GUI selection (for tracking area update procedure)
    2. Try to change RRC connection release's release cause from 'load balancing TAU required' to some other cause (like 'other') in tester GUI selection
    If not possible then Anritsu needs to be contacted"
  • Here's the feedback from the lab:
    "The 2 suggestions that were made by Nordic, were not possible to do on our Anritsu MT8821C callbox. Integrity protection can only be changed from NULL to Snow 3G, we have it set to Snow 3G.  The RRC connection is either on or off, we normally have it defaulted to Off."
    I've also attached to this message screen shots of their settings on the callbox.
    Ultimately, the test lab was able to get the nRF9160 to work for AT&T but not Verizon.  However, the calls on AT&T would only stay active for 3-4 minutes before the nRF9160 would drop the call.
    Any idea why it won't work on the Verizon bands? Or why it would only connect for a few minutes on the AT&T band?
     It is hard to tell without a modem trace. Is it possible for you to do a modem trace from the same setup?
  • Were you able to connect Anritsu with nRF9160 longer than 3-4 minutes? I am also in the WRCNC trying to measure TIS and TRP in NBIoT Mode. It seems like you are using CAT-M1, right? I opened a case and read yours to see if you had a resolution but see none. My case ID is 257594. Thanks!
