SAADC missing event
Hello.
I have a issue about missing NRF_DRV_SAADC_EVT_DONE event in saadc  handler.
setup is 52832, SDK 15.3.0, S332. enable ANT, BLE
for battery, sensor, I use 2 adc channel.
buffer size is 2.
like ' adc_buffer[2][ADC_BUFFER_SIZE] '.
adc interval is 10ms, adc sampling through ppi
app timer start rtc timer for intrrupt ppi , app timer interval is 9ms, rtc interval is 1ms.
routine is below.
app timer handler -> adc & ppi init -> rtc timer start -> timer rasie interrupt to ppi -> sampling ->  saadc handler -> Done event -> get adc value -> do something -> ppi uninit -> adc uninit
most case, it work very well.
however, sometimes it stop and issue error code 8 : already initalize saadc.
so I checked the cause, when the issue happened, Done event is not raise. it was missed. so it didn't process uninit.
for reducing power consumption, try init & uninit repeatly.
I also tried 'uninit' move to main loop. not callback.
even though, it still issue intermittently.
Could you give me advices?
Thank you in advance.
