How to retrieve Value from multiple Characteristics based Service Handler p_ble_evt->header.evt_id.?
 I have one service UUID ffe0 that has two characteristics: one of has UUID ffe4 use for "notify" and other one has UUID ffe5 use for "write and read".
Now i want to get the data from the FFE5 and reply accordingly as per the data that I received from FFE5 suppose I write send data from mobile App to board is "SEND=1" as string to characteristic  UUID FFE5 now according to the message received from the FFE5 service i.e. SEND=1 I want to reflect the characteristic UUID FFE4 as "OK" if the string matches as SEND=1. Now My main Question is How i know when the data is being received from FFE5 characteristic UUID. If I get that as an interrupt or anything I will send a reply as "OK" over the characteristic  UUID FFE4.
I have also created NRF_SDH_BLE_OBSERVER for that service.
But how to get value from the different characteristics UUID like 0xFFE5 and so forth if any .
            case BLE_GAP_EVT_CONNECTED:
                p_our_service->conn_handle = p_ble_evt->evt.gap_evt.conn_handle;
                p_our_service->conn_handle = BLE_CONN_HANDLE_INVALID;
                // No implementation needed.
Thanks in advance.
  • Looks good!
    One tiny thing you can look into if you want to power optimize your application (minor detail).
    Your do{} while() loop will make sure that the packet is sent in a proper way. However, if you ever get the NRF_ERROR_RESOURCES return value, you will not allow the chip to go to sleep before it returns NRF_SUCCESS. To further optimize this, you can save the data in some array in your application, leave the event, and then retransmit it on the next BLE_GATTS_EVT_HVN_TX_COMPLETE (you can add this event to your main.c's ble_evt_handler()).
  • OK Thank you for evaluating it,
    I understand your point about the consequences of the do{} while() loop  with NRF_ERROR_RESOURCES,
    But i am still not sure how to implement as you explained in as
    Can you please explain as in some code snippet of the same thing i want to do as per your technique!
    It would be great help to have !
    And also one thing that i explained is the trigger of the RX characteristics is important to me as to know that data is received too.
  • volatile bool send_flag = false;
    volatile bool more_data = false;
    volatile uint8_t data_array[MAX_LENGTH];
    volatile uint16_t data_length;
    static void ble_evt_handler(...)
        case BLE_GATTS_EVT_HVN_TX_COMPLETE:
            if (more_data)
                send_flag = true;
            // Copy data from event to your custom data_array.
            for (uint8_t i=0; i<p_evt->....len; i++)
                data_array[i] = p_evt->....data[i];
            data_length = p_evt->...len;
            send_flag = true;
            more_data = true;
        // Init everything.
        for(;;)
            if (send_flag)
                send_flag = false;
                err_code = send_data()
                if (err_code == NRF_SUCCESS)
                    more_data = false;
            idle_state_handle
    Something like this. Send the data from main, and only try again if the TX_COMPLETE event occurs and you have more data to send.
    BR,
    Edvin
  • Ok thank  for really quick help and I got it ,
    Just to confirm the send_data() would it be as below?:
    uint32_t send_data(void)
        return ble_nus_data_send(&m_nus, data_array, &data_length, m_conn_handle);
    Is above send_data() function enough or more preventive code require as far as other nRF flags are concerned ?
  • It worked as you told without NRF_ERROR_RESOURCES as per your suggested code snippet and also above send_data function too.
    Is any other preventive measure to take care of  for final implementation !!!
    Please give suggestion for the same.
    Thank you in advance.
