Network collapse when Zigbee light bulb example runs
Hello to all,
i've developed some application under 3.2.0 SDK. Now I want to port my application on new 4.1.0 SDK but a I have found a relevant issue.
Before migrating my application (I read migration guide and the modifications are consistent), I decided to try light bulb example.
When the example runs all network activity stops, on the sniffer the last message is identified as "beacon request".
Until the example is still running, I can't see any other message, any command from coordinator and other device (and vice-versa) doesn't work.
I attach sniffer trace sdk_410_starts.pcapng to show you wath happens. In order to view the trace this is the key: 8a:89:a1:cc:a3:66:11:15:05:88:8f:a7:9e:f5:99:67
BR,
Maurizio
  • Hi Edvin,
    But you said that the network stops working after you turn it on, is that the case?
    I confirm.
    So it is not something you have made? It is a product that you bought of the shelf?
    Yes, the coordinator is a commercial product.
    What device? And do you mean power cycled? What happens then?
    The device running Light Bulb Example as mentioned above.
    I just tested the light bulb with a coordinator running on the CLI example, both running on pca10056 boards. No issues there.
     I tried this setup before on SDK 3.2.0 and after on SDK 4.1.0. These is the results:
    On SDK 3.2.0 I programmed one board as CLI and the other one with Light Bulb Example. At startup the board with Light Bulb Example has LED 4 switched on and LED3 switched off. On CLI I issue:
    bdb channel 11
    bdb role zc
    bdb start
    LED3 on the board with Light Bulb Example is switched on to indicate right association.
    Then I issued this command:
    zcl cmd F4CE368732AA67A8 10 0x0008 -p 0x0104  0x00 -l 00ffff
    LED4 on the board with Light Bulb Example is switched off in response of my level control command
    And at the end I issued this command:
    zcl cmd F4CE368732AA67A8 10 0x0008 -p 0x0104  0x00 -l ffffff
    LED4 on board with Light Bulb Example is switched on again.
    At this point I executed "nrfjprog --eraseall" for each board and then I programmed with SDK 4.1.0.
    I ran the same commands but on the board with Light Bulb Example LED4 is alway on and LED3 is always off.
    You say that you have no issues with this setup, what tests did you get after bdb start?
    BR,
    Maurizio
  • Well, initially I only checked that the LED3 was turned on, indicating that the bulb had successfully joined the network. But when you wrote this, I tested the same set of procedures on both 3.2.0 and 4.1.0. In my case, it worked in both versions. (Wait to send the match desc until LED3 turns on).
    These are the commands that I used:
    > bdb role zc
    Coordinator set
    Done
    > bdb channel 11
    Setting channel to 11
    Done
    > bdb start
    Started coordinator
    Done
    > zdo match_desc 0xffff 0xffff 0x0104 1 0x0006 0
    Sending broadcast request.
    src_addr=72E5 ep=10
    > zdo ieee_addr 72e5
    f4ce3752d0756231
    Done
    > zcl cmd f4ce3752d0756231 10 0x0008 -p 0x0103 0x00 -l 00ffff
    Done
    > zcl cmd f4ce3752d0756231 10 0x0008 -p 0x0103 0x00 -l ffffff
    Done
  • I've some updates for you.
    As I said, I've two boards, one is a PCA10056 and the other is MDBT50Q-DB (from RAYTAC).
    I never used PCA10056 as CLI or sniffer because has faulty nRF USB port so I always used PCA10056 to run the Light Bulb Example which does not need USB to work.
    Today I tried to use my original coordinator (based on ETRX357 Telegesis) and MDBT50Q-DB to run the Light Bulb Example over 4.1.0.
    Now it work!
    Then seems that faulty USB port on PCA10056 is the responsible for the problem.
    Probably the same example based on 3.2.0 don't care about this.
    BR,
    Maurizio
