f_write/f_close cause BLE disconnect
Hardware: nrf52832
SDK: 16.0.0 with FreeRtos,
Softdevice: S132 7.0
I set configMAX_PRIORITIES to 5 and modified nrf_sdh_freertos_init to set BLE task priority to 4.
My sd card maintain task priority is set to 2.
For BLE NUS service:
#define MIN_CONN_INTERVAL MSEC_TO_UNITS(20, UNIT_1_25_MS) /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
#define MAX_CONN_INTERVAL MSEC_TO_UNITS(75, UNIT_1_25_MS) /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
#define SLAVE_LATENCY 0 /**< Slave latency. */
#define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Connection supervisory time-out (4 seconds). */
The NUS service and SD card function works fine when test them separately. But if Operate SD card during NUS connection, I got disconnect with reason:0x8
I have tried to enlarge INTERVAL to 120ms/175ms, also tried to change SLAVE_LATENCY to 4. Problem still exist.
I searched internet and NRF Dev Zone, found some similar question, but none of them can resolve my problem. So I have to raise a new question here.
  • Dear Simonr:
       Thank you very much for your support. Since it is night time on my location, I am out of office now. So I can not access detail source code.
       About "should not edit SoftDevice's priority", do you mean the "interrupt priority" or "freeRtos task priority"?
       I have not change any interrupt priority. And for task priority, since the default BLE task priority is set to 2 and the LOG task priority is 1, there is no room for my tasks ( I have 2-3 tasks ). So I do following change:
  • What devices are you testing this on?
    I buy a Development Board from internet and the board is marked "PCA10040 compatible". I can provide schem of the board when I back to office tomorrow.
    and I'm guessing this is because the SD card operations are allowed to interrupt the radio
      I think this guess is reasonable. What can I do to verify or avoid this happen?
  • Hi
    Lowering the BLE task priority and giving other tasks priority over it will cause the radio to be interrupted and cause disconnections. You should revert any changes you have made to the BLE task priority and set the SD card tasks to a lower priority so that it doesn't interfere with the radio at all. The default BLE task and LOG task priorities should be left alone, as they require the highest priority available. Please try setting your "custom tasks" to 4, 5, and 6 for example as that should prevent the radio from being interrupted.
    Simon
  • Dear Simonr:
        Sorry I am little bit confused: On freeRTOS, the bigger number should mean higher priority. That's why I modified BLE task priority to 5 and my own task's priority is 2,3.
        Do you mean on NRF freeRtos, bigger number means lower priority?
        I think my understanding is correct because I can see the IDLE task's priority is 0
  • Dear  Simonr:
       I did a new test: replace SD operation (f_open/f_write/f_close) part with a heavy load float computing function(need more than 800ms to finish). This float computing is running every 1 seconds. The BLE connection is very stable.
      If we name "sd operation" as  A, and name "float computing" as B, then we have following comparation:
    * A cost less CPU than B (A use about 150ms per second , B use 800ms per second)
    * A/B locate on same position of same task (means on same logic sequence with same TASK priority)
    * A will cause BLE disconnect. But if replace A with B, BLE connection is stable.
       Consider above information. I think this disconnect issue seems not related to task priority or CPU consumption.  The problem maybe in FatFs/blkdev/sdc driver ?
