Hi guys, I just want to know if there's a way for the above and how if yes.
Hi Jerry,
That could be a problem with SPI PHASE and POLARITY.
Kindly check all the 4 cases with those.
Warm Regards,
Kumar
Hi,Kumar
I had think about that and I've tried to check all the 4 cases. But, strangely, the device ID returned was always 0x00 in the 4 cases.....
nrf_drv_spi_transfer() returned NRF_SUCCESS, seemed that there's no problem in transmission. But the returned value 0x00 showed that read_data function wasn't work.......
Have you read and write icm successfully by spi?Can you show me your code for a example?
thanks a lot.
Jerry
Hi Jerry,
Should there be a command delay between the write, read functions?
Or try a different function for reading from SPI DRIVER instead of spi_transfer one. HAL_SPI DRIVER functions are better if we have.
Also, make sure that MISO and MOSI are properly connected, just in case.
No, I couldn't work on that sensor as I moved to a ST one
