RC oscillator Frequency tolerance for LFRC after calibration(accuracy increment)
Dear Nordic,
We have almost completed development with nRF52810.
We are trying to improve the accuracy of product operation.
RC oscillator(LFRC) is currently used as the internal clock source.
Frequency tolerance for LFRC after calibration is shown as +/- 500ppm on the datasheet.
 * Constant temperature within ±0.5 °C and calibration performed at least every 8 seconds, defined as 3 sigma
The part I can't understand is below.
# 32.768 kHz RC oscillator (LFRC)
    Frequency tolerance for LFRC after calibration / ± 500 ppm
# 32.768 kHz crystal oscillator (LFXO) specification.
    Frequency tolerance requirement for BLE stack / ± 250 ppm
1. Why is the Frequency tolerance range applied to the RC oscillator(LFRC) and Crystal oscillator(LFXO) set differently?
1.1 Why is the Frequency tolerance for LFRC after calibration that didn't meet the specifications(Frequency tolerance requirement for BLE stack / ± 250 ppm)?
2. Is there a way to set the Frequency tolerance for LFRC after calibration of RC Oscillator to ± 250ppm?
2.1 Or RC Oscillator can it be set under ± 250 ppm?
3. Should I use an external crystal to need a frequency tolerance under ± 250ppm?
4. Is there any problem running the BLE stack even at RC oscillator(LFRC) frequency tolerance ± 500 ppm?
Thank you and Best Regards,
Sungsuk Han.
  • Hi Einar,
    The model name we applied for development is nRF52810.
    Looking at the datasheet, nrf52810 is all RC oscillator frequency tolerance is +/-500ppm(after calibration) from PS_v1.0 to PS_v1.3.
    As you can expect from this, the nRF52810 designed at +/-500ppm from the beginning.
    Additionally, as described in the datasheet, the frequency tolerance requirement for the BLE Stack is +/-250 ppm, so the RC oscillator frequency tolerance +/-500ppm is unacceptable.
    By the way, RC oscillator(LFRC) frequency tolerance is +/-500ppm enough, but why should external crystal(LFXO) frequency tolerance be +/-250ppm?
    External crystal(LFXO) frequency tolerance is +/-500ppm should be enough.
    This confuses me. I think this has a clear reason.
    Otherwise,Hmm.... I think the specification of frequency tolerance requirement for BLE Stack is wrong.
    Sungsuk Han.
  • Hi Sungsuk,
    Yes and no. The nRF52810 is a subset of the nRF52832, wit some fixes to HW and documentation. There is no real difference here, just that for the S132 there is a discrepancy between the datasheet and reality, hence the erratum. And for this reason, the datasheet for the nRF52810 RC oscillator was updated to reflect the reality instead of having the erratum. But that does not imply a difference in the actual HW.
    The datasheet is inaccurate in this regard. The SoftDevice (BLE stack) was updated to support a +/-500 ppm RC oscillator when it was discovered that the HW did not meet +/- 250 ppm. This has no practical implications.
    What do you mean?
    Yes. The reason is as explained above: the RC oscillator for the nRF52832 was intended to have +/- 250 ppm accuracy, and the original documentation reflects that. Then, because of erratum 146 for nRF52832, this was adjusted to +/- 500 ppm, and the SoftDevice was also updated. And since the nRF52810 is a subset of the nRF52832, the same applies to it, though it looks different in the PS since it was released after the erratum was discovered.
    Yes, for the LFXO that is the case, unfortunately. But please note that it has no practical implications since it makes little sense to use a crystal that is worse than +/- 250 ppm, as then you could just as well use the internal RC.
    Einar
  • Hi Einar,
    "External crystal(LFXO) frequency tolerance is +/-500ppm should be enough."
    I tried to explain the above content as below.
    1. The RC oscillator(LFRC) frequency tolerance +/- 500 ppm fully support for BLE stack.
    2. If so, the External crystal(LFXO) frequency tolerance +/- 500 ppm can fully support for BLE stack, too. (Not necessarily +/-250 ppm.)
    3. The specification of frequency tolerance requirement(+/-250ppm) for BLE Stack is wrong.
    4. The frequency tolerance requirement for the BLE Stack is +/-500 ppm.(+/-250ppm -> +/-500ppm)
    5. There is no problem with using external crystals(LFXO) with frequency tolerance of +/-500 ppm.
    Your great support has helped me a lot.
    Thank you very much.
    Sungsuk Han.
  • Hi Einar,
    All my questions have been solved.
    Thank you very much for your help for a few days.
    Best Regards,
    Sungsuk Han.
