ble fall in init after addition of twi
hello
i am working with nrf52832
my code is based on the Ble blinky example from centeral. i added to the code with ble, uart, saadc and pwm and it was working great
after addition of twi with sdk_config file addition which unfortunetly i didn't save before changes, and addition of a lib of nxp nfc reader, i fall in ' ble_init '
i get stuck here:
SVCALL(SD_SOFTDEVICE_ENABLE, uint32_t, sd_softdevice_enable(nrf_clock_lf_cfg_t const * p_clock_lf_cfg, nrf_fault_handler_t fault_handler));
in the nrf_sdm.h file
i think it is related to the softdevice but i have no idea what changed (the ble files did not, the only thing i can think of is the sdk_config.h or the .emProject file
any help on the metter will be most appritiated
Best regards
Ziv
  • Hello Ziv,
    ziv123 said:
    i tried to change some things related to twi and timer but every change i made i reversed it and now it is working i have no idea why cause eventualy nothing was changed..
    Are you certain that you did not change anything in the config?
    I would recommend you to familiarize with a version-tracking tool(such as github) to easily track the changes you have made, and to be able to quick and easily revert to a functioning version of your applications.
    ziv123 said:
    it would have been halpfull if there was a good guid for each driver on how to config the sdk_config file and where this configuration may colide with other things
    You could see this in the Shared Resources section of each modules documentation, in the TWIM case you could read about it here. Mainly, you will have to look out for the shared ID's, which you can see an overview of in the Instatiation table.
    ziv123 said:
    anyway, no i have some issue with twi but i will open a new topic for that i think
    Yes, please do so.
    ziv123 said:
    thanks for now, hope this issue will not return
    No problem at all, I am happy to help.
    Karl
  • I would recommend you to familiarize with a version-tracking tool(such as github) to easily track the changes you have made, and to be able to quick and easily revert to a functioning version of your applications
    i am using one but since the config lib is out of the ses lib so it was not added till now to the git server
    i am reading the documentation of each driver i am working on but most of the info there is more relevant to hardware, there is no real api or software support beside this forum, the sdk examples does give something to start with but are lacking many things or on the other hand to general, integration of modules and the complications of that is not explained anywhere, again except from this forum and it takes a long time to search for similar problems that also got firm solutions .. hope nordic will improve in that aspect of software people documentation support
    thanks for now :)
  • Hello again Ziv,
    Great, I am glad to hear you are already doing this!
    I agree that it would be favorable if the process of merging functionality from different modules was more streamlined, but it is hard to make happen given the variety of applications that our customers make.
    Thank you for your feedback regarding the documentation and usage of the different modules, we are always looking for ways to improve the development process for our customers.
    ziv123 said:
    thanks for now :)
    I am happy to help you Ziv!
    Please do not hesitate to let us know if you should encounter any other issues or questions.
    Karl
