How to find error causing code witch is caugt by app_error_weak.c
I have built a custom chip with nrf52840 on it.
I use Ses as development tool.
I took as startingpoint for software SDK15.3 with Softdevice 140
I took the ble_template from the SDK and copied my code init.
I can compile the code without any error, but when I flash it on the device it does not start to advertise.
In debugger mode it starts up well, but then runs into app_error_weak.c
now the function gives error code and stuff, but I don't know, how to find the code witch caused the error
that is what i got from ses and the error handler
I'm not sure if its relevant but in call stack ar two functions in it
the first is in app_error_weak.c
the secound is in app_error_handler_gcc.c
and shows those parameters
because error_code in one handler and id in the other ar the same i guess, that 1 error is thrown and chaugt by both handlers, or
one handler calls the other.
But I don't know now how to solve this. And how to search for the code whitch caused the error.
thanks for any help
  • I steped slowly trouhg the program to search where the error is happening...
    the function sd_ble_enable() returns 0x4 as I found in an other forum entry this means no or not enough memory...
    should i now try to change RAM start or RAM size?
  • So I tryed to change RAM_START, and  RAM_SIZE
    New RAM_START  : 0x20001ff8
    New RAM_SIZE : 0x2008
    Now sd_bleenabe() returns 0x0 what mean success...
    sd_ble_event_get() returns 0x5 this means that no ble_event is in stack, thats ok then
    but it did still not advertise
  • sd_ble_evt_get returning NRF_ERROR_NOT_FOUND is a normal scenario where softdevice tells that there are no more events to be pulled out.
    If your application has called sd_ble_gap_adv_start without any errors, then I do not understand why the device is not advertising. Please make sure that your application starts in debug mode and put a breakpoint inside app_error_fault_handler to find out if any APP_ERROR_CHECK failures.
  • at the moment I'm debugging
    the function sd_advertising_start() returns 8 invalid state
    in this funciton it is a call to
    ble_advdata_set() returns 7 invalid parameter
    in this function is a call to
    sd_ble_uuid_encode() returns also 7
    after sd_ble_uuid_encode() returns error code the function hangs up in a infinity loop
    were it always enters sd_advertiseing_start() and always returns 8
    but never ever passes the breakpoint by ble_advdata_set() or
    but in the infocenter i can not find clear informations about this function,
    All information I found about this is ...
    I don't have a clue what this minimalistic information should give me...
  • Could it be, that SES whant's to load all on RAM in debugging?
    The chip has 1MB Flash and 256 kB RAM...
    in SES it says :
    that gives a total of 273.8 kB what is more then we have in RAM only
    I 'm looking for a needle in a haystack pleas show me the needle
