Coded PHY Advertising on nRF Connect SDK
Hey All,
I ran into an issue on the nRF Connect SDK trying to get a nRF52840 advertising using CODED PHY. I figure it's not fully implemented yet are there any updates on timeline for that? I also posted a bug in the Zephyr repo.
Describe the bug
BLE advertising failed to start on a nRF52840 when enabling BT_LE_ADV_OPT_EXT_ADV.
[00:00:00.002,960] <inf> ble_m: BLE Stack Ready!
[00:00:00.002,960] <inf> ble_peripheral: Bluetooth initialized
[00:00:00.002,960] <err> ble_peripheral: Advertising failed to start (err -22)
To Reproduce
  1. Choose any BLE example
  2. Use a compatible board like nrf52840dk_nrf52840
  3. Add CONFIG_BT_EXT_ADV=y to your prj.conf
  4. When initializing struct bt_le_adv_param *adv_param = add these two flags BT_LE_ADV_OPT_CODED | BT_LE_ADV_OPT_EXT_ADV
Looks like this:
struct bt_le_adv_param *adv_param = BT_LE_ADV_PARAM(BT_LE_ADV_OPT_CONNECTABLE | BT_LE_ADV_OPT_ONE_TIME | BT_LE_ADV_OPT_CODED | BT_LE_ADV_OPT_EXT_ADV, BT_GAP_ADV_FAST_INT_MIN_2, BT_GAP_ADV_FAST_INT_MAX_2, NULL);
For instance, if I used the throughput example in the SDK and try to set BT_LE_ADV_OPT_CODED | BT_LE_ADV_OPT_EXT_ADV as some of the parameters it always return -22. Looking further into it, it appears that CODED PHY advertising is (purposefully?) disabled in valid_adv_param.
Any insight is appreciated!
  • the problem is, Zehpyr can't see the NRFxlib
    I followed this tutorial to install NRFx with zephyr with no luck
    https://jimmywongiot.com/2019/12/18/step-by-step-on-nordic-connect-sdk-for-development/
    tried also to copy the nrfxlib and import the kconfig file into my zephyr enviroment.
    https://github.com/nrfconnect/sdk-nrfxlib
    actually, I find nowhere in any file on nrfx library this text "LL_NRFXLIB"
    tried also to include CONFIG_SOFTDEVICE_CONTROLLER_S140 with no luck.
    so, What do i miss?
    I always get
    prj.conf:9: warning: attempt to assign the value 'y' to the undefined symbol BT_LL_NRFXLIB_DEFAULT
    same for CONFIG_BT_LL_NRFXLIB_VS_INCLUDE
    this is my prj.conf
    CONFIG_BT=y
    CONFIG_BT_BROADCASTER=y
    CONFIG_BT_OBSERVER=y
    CONFIG_BOARD_NRF52840DONGLE_NRF52840=y
    # Link Layer
    #NRF
    #CONFIG_SOFTDEVICE_CONTROLLER_S140=y
    CONFIG_BT_LL_NRFXLIB_DEFAULT=y
    #NRF
    CONFIG_BT_EXT_ADV=y
    CONFIG_BT_CTLR_PHY_CODED=y
    CONFIG_GPIO=y
    CONFIG_USB=y
    CONFIG_USB_DEVICE_STACK=y
    CONFIG_USB_DEVICE_PRODUCT="Qoudra BLE"
    CONFIG_USB_UART_CONSOLE=y
    CONFIG_UART_LINE_CTRL=y
    CONFIG_UART_CONSOLE_ON_DEV_NAME="CDC_ACM_0"
