Can not upload HEX file
Hello!
Thanks for your help last time, highly appreciated.
However I haven't got till actuall programming because now I can't upload hex files. I start Thingy:91 in boot mode, connect, press write and it immidiately goes in application mode and programmer sofware throws error that I have to check that it is in boot mode. I have no clue how to fix this. Any hints?
Edit: This videoplayer seems to be out of order. Uploaded video to youtube.
Kind regards!
  • Thank you for your involvement.
    When you say "the same thingy device", do you mean your friend's own thingy91, or the physically same device as you are having trouble with?
    Physically same device
    It seems that your device does not have the MCUboot
    so this seems to be not the case.
    If you then flash one of the newest samples onto your kit, it will also contain the MCUboot.
    We also did that with 10 pin connector.
    I guess I will renistall nRF Connect later today. Not a big hope tho.
    No problem at all, I am happy to help and I hope we are able to resolve this issue shortly.
    Agreed, if you were able to flash the physically same device then the MCUboot must be present.
    Do you know which operating system and nRF Connect version your friend was using?
    I will check with the nRF Connect team, to see if they have any insight on the issue. I will update you when I have spoken with them.
    Karl
  • Hello again,
    Could you also verify for me which JLink version you have? In the case that it is not the latest version ( v6.80a ) then please update that as well.
    This would be highly beneficial to know, in addition to the questions posed in my previous reply.
    I am not sure that reinstalling nRF Connect will resolve this issue, but you may very well attempt it.
    Let me know how it goes.
    I am looking forward to resolving this issue together!
    Karl
