I'm using the Segger nRF52840-DK and I want to add support for SPI?
I'm using the nRF52840-DK evaluation software from Segger. I want to add NAND Flash support, so I want to add an SPI interface. I have looked at the example in nRF5SDK160098a08e2 and that works nicely on my board, but I'm having difficulty moving that SPI example to the nRF52840-DK project as there are dependencies on Integration, module and components folders. isn't there a much simpler way to just add SPI support like there is when using ST Micro Cube IDE? I did manage to have a successful build with nrfx version of SPI, but the driver won't work correctly on my board.
I'm using the latest version of Segger Embedded Studio.
John
  • Hello John,
    john3909 said:
    Thank you for all your help.
    No problem at all, I am happy to help!
    john3909 said:
    The only problem I have is I still have to use Segger's emFile because I still need their NAND universal driver to talk to the Kiokia TH58CBG2S0HRAIJ part.
    I tried to look up the part you mention, but I was unable to find one matching that exact part number.
    The SDK fatfs driver documentation can be found in the SDK, located at: PATH/SDK/external/fatfs/doc/00index_e.html
    Were you able to run the example I provided without issue, by the way?
    - Is there any fatfs functionality you are missing with the fatfs driver provided in the SDK?
    Karl
  • Hi Karl,
    The part is compatible with any Kioxia (previously Toshiba) SPI part:
    https://www.digikey.com/products/en/integrated-circuits-ics/memory/774?k=nand+flash&k=&pkeyword=nand+flash&sv=0&pv142=227634&sf=0&FV=-8%7C774%2C-1%7C1853&quantity=&ColumnSort=0&page=1&pageSize=500
    For Segger emFile, I only had to write the SPI access layer (init, read byte, write byte, lock, unlock, etc). Their universal driver would read the part ID and then use the appropriate command structure to access the part. For your part, I would have to write the sector/block code and deal with ECC, etc. Am I correct? Do you have an example driver I can use for reference.
    John
  • Oh, and one more thing, we are also looking at using eMMC with SDIO 4 or 8Bit mode to minimize the time to write. This is a requirement because we would like to run on a CR2032 battery for 8 hours.
    John
  • Hello again John,
    The modern eMMC standard does not support SPI, and the nRF52840 does not support eMMC so to achieve this you would need an additional eMMC controller IC. For more detail please see this ticket.
    What other peripheral do your application use, and how often is it in use?
    I do not know anything about your application or its use-case, but 8 hours is a very short lifespan of a device in the field. Is it perhaps meant to be deployed as a temporary sensor unit of some sorts?
    I would think 8 hours as a target is achievable - but then again I do not know much about what you plan on having the device do.
    If you could elaborate more on that, I could advice you on power optimization.
    No, if I understand what you are asking me correctly, this is handled by the fatfs driver - ie. you may use all the functions listed in the /external/fatfs/doc/00index_e.html documentation directly, once you have fatfs disk is initialized. The initialization abstracts the memory to a block device, which is an universal abstraction for block based memory - from there on out all fatfs volumes are accessed the same.
    Karl
  • Hi Karl,
    The device has several sensors that are sampled every 2mS and stored to a 128K buffer and then stored to SDCard when the buffer is full. The SDCard is the only device that consumes a lot of power (100mA during read/write), so we have this powered down for most of the time and only power up when writing. We want to keep the write as short as possible, so a 4bit operation is preferred.
    Do you have an NAND Flash example driver we can used as a reference. The link you provided refers to another document that is referencing the same part as ours, but on the BMD340 part.
    Thank you for all your help,
    John
