Hello Everyone,
I started to use the NRF52832 recently and wanted to use it with a sensor from Melexis called MLX90632. I am using sdk 15.0.0.
This sensor have a library provided with it that helped me understand better how does the sensor work but i am blocking on the read and write function.
They have an example for the STM32 MCU ( https://github.com/melexis/mlx90632-example) that should be i should be able to replicate using the NRF52 function and drivers but i can't manage to make it work. In theory i should only modify the main file and not the library pre-built function.
While calling the function that i wrote i get the NRF_SUCCESS but i can't get actual values from the functions.
I believe the error might be located in the functions : mlx90632_i2c_read or mlx90632_i2c_write
Here is my main file for better understanding of my issue.
* Copyright (c) 2015 - 2018, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
/** @file
* @defgroup tw_sensor_example main.c
* @ingroup nrf_twi_example
* @brief TWI Sensor Example main file.
* This file contains the source code for a sample application using TWI.
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
#include "nrf_twi_mngr.h"
#include "nrf_twi_sensor.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/* Sensor Declarations*/
#include "mlx90632.h"
/* TWI instance ID. */
#define TWI_INSTANCE_ID 1
#define MAX_PENDING_TRANSACTIONS 8
#define NRF_TWI_SENSOR_SEND_BUF_SIZE 8
typedef void(* nrf_twi_sensor_reg_cb_t)(ret_code_t result, void *p_register_data);
/* Common addresses definition for temperature sensor. */
#define SensorAdress (0x3A>>1) //#define LM75B_ADDR (0x90U >> 1)
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
NRF_TWI_MNGR_DEF(m_nrf_twi_mngr, MAX_PENDING_TRANSACTIONS, TWI_INSTANCE_ID);
NRF_TWI_SENSOR_DEF(m_nrf_twi_sensor, &m_nrf_twi_mngr, NRF_TWI_SENSOR_SEND_BUF_SIZE);
int temperature_skin = 0;
int raw_temperature=0;
double pre_ambient, pre_object, ambient, object;
void twi_mngr_init (void)
ret_code_t err_code;
const nrf_drv_twi_config_t twi_sensor_config = {
.scl = I2C_SCL,
.sda = I2C_SDA,
.frequency = NRF_DRV_TWI_FREQ_100K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH,
.clear_bus_init = false
err_code = nrf_twi_mngr_init(&m_nrf_twi_mngr, &twi_sensor_config);
printf(nrf_strerror_get(err_code));
/* Implementation of I2C read for 16-bit values */
int32_t mlx90632_i2c_read(int16_t register_address, uint16_t *value)
uint8_t data[2];
int32_t ret;
nrf_twi_sensor_reg_cb_t user_cb;
ret = nrf_twi_sensor_reg_read(&m_nrf_twi_sensor,SensorAdress,register_address,user_cb,data,sizeof(data));
printf(nrf_strerror_get(ret));
//Endianness
*value = data[1]|(data[0]<<8);
return ret;
/* Implementation of I2C read for 32-bit values */
int32_t mlx90632_i2c_read32(int16_t register_address, uint32_t *value)
uint8_t data[4];
int32_t ret;
//Endianness
*value = data[2]<<24|data[3]<<16|data[0]<<8|data[1];
return ret;
/* Implementation of I2C write for 16-bit values */
int32_t mlx90632_i2c_write(int16_t register_address, uint16_t value) {
uint8_t data[2];
data[0] = value >> 8;
data[1] = value;
int32_t ret ;
return nrf_twi_sensor_reg_write(&m_nrf_twi_sensor,SensorAdress,register_address,data,sizeof(data));
/* Implementation of reading all calibration parameters for calucation of Ta and To */
static int mlx90632_read_eeprom(int32_t *PR, int32_t *PG, int32_t *PO, int32_t *PT, int32_t *Ea, int32_t *Eb, int32_t *Fa, int32_t *Fb, int32_t *Ga, int16_t *Gb, int16_t *Ha, int16_t *Hb, int16_t *Ka)
int32_t ret;
ret = mlx90632_i2c_read32(MLX90632_EE_P_R, (uint32_t *) PR);
if(ret < 0)
return ret;
ret = mlx90632_i2c_read32(MLX90632_EE_P_G, (uint32_t *) PG);
if(ret < 0)
return ret;
ret = mlx90632_i2c_read32(MLX90632_EE_P_O, (uint32_t *) PO);
if(ret < 0)
return ret;
ret = mlx90632_i2c_read32(MLX90632_EE_P_T, (uint32_t *) PT);
if(ret < 0)
return ret;
ret = mlx90632_i2c_read32(MLX90632_EE_Ea, (uint32_t *) Ea);
if(ret < 0)
return ret;
ret = mlx90632_i2c_read32(MLX90632_EE_Eb, (uint32_t *) Eb);
if(ret < 0)
return ret;
ret = mlx90632_i2c_read32(MLX90632_EE_Fa, (uint32_t *) Fa);
if(ret < 0)
return ret;
ret = mlx90632_i2c_read32(MLX90632_EE_Fb, (uint32_t *) Fb);
if(ret < 0)
return ret;
ret = mlx90632_i2c_read32(MLX90632_EE_Ga, (uint32_t *) Ga);
if(ret < 0)
return ret;
ret = mlx90632_i2c_read(MLX90632_EE_Gb, (uint16_t *) Gb);
if(ret < 0)
return ret;
ret = mlx90632_i2c_read(MLX90632_EE_Ha, (uint16_t *) Ha);
if(ret < 0)
return ret;
ret = mlx90632_i2c_read(MLX90632_EE_Hb, (uint16_t *) Hb);
if(ret < 0)
return ret;
ret = mlx90632_i2c_read(MLX90632_EE_Ka, (uint16_t *) Ka);
if(ret < 0)
return ret;
return 0;
void usleep(int min_range, int max_range) {
while(--min_range);
void twi_sensor_init(void){
err_code = nrf_twi_sensor_init(&m_nrf_twi_sensor);
int16_t ambient_new_raw;
int16_t ambient_old_raw=25;
int16_t object_new_raw;
int16_t object_old_raw=25;
int32_t PR = 0x00587f5b;
int32_t PG = 0x04a10289;
int32_t PT = 0xfff966f8;
int32_t PO = 0x00001e0f;
int32_t Ea = 4859535;
int32_t Eb = 5686508;
int32_t Fa = 53855361;
int32_t Fb = 42874149;
int32_t Ga = -14556410;
int16_t Ha = 16384;
int16_t Hb = 0;
int16_t Gb = 9728;
int16_t Ka = 10752;
NRF_LOG_INFO("\r\nTWI sensor example started.");
NRF_LOG_FLUSH();
twi_mngr_init();
twi_sensor_init();
mlx90632_read_eeprom(&PR, &PG, &PO, &PT, &Ea, &Eb, &Fa, &Fb, &Ga, &Gb, &Ha, &Hb, &Ka);
while (true)
nrf_delay_ms(1000);
mlx90632_read_temp_raw(&ambient_new_raw, &ambient_old_raw, &object_new_raw, &object_old_raw);
pre_ambient = mlx90632_preprocess_temp_ambient(ambient_new_raw, ambient_old_raw, Gb);
pre_object = mlx90632_preprocess_temp_object(object_new_raw, object_old_raw, ambient_new_raw, ambient_old_raw, Ka);
mlx90632_set_emissivity(1.0);
ambient = mlx90632_calc_temp_ambient(ambient_new_raw, ambient_old_raw, PT, PR, PG, PO, Gb);
object = mlx90632_calc_temp_object(pre_object, pre_ambient, Ea, Eb, Ga, Fa, Fb, Ha, Hb);
printf("\nTemperature of new object : %d Celsius degrees.", object_new_raw);
printf("\n Temperature of old object: %d Celsius degrees.", object_old_raw);
NRF_LOG_FLUSH();
I hope you can provide some insight on what my issue might be.
Guillaume
