What's the difference nrf_cloud_agps and AGPS using google SUPL data?
I'm not clear about this. README.rst doesn't explain about it.
Also, to use the nrf_cloud_agps, do you have to use iBasis SIM?
Hi
I believe AGPS, LTE, and eDRX all should be supported in the asset_tracker application in NCS v1.3, so I would suggest starting from there and adding what you need from there.
Simon
I could merge AGPS and eDRX or PSM so now I'm ok. Thank you for your support!
>The data that is used in the nrf_cloud_agps and AGPS using Google SUPL data should be the same, but the vendor of the data and the protocols are different.
Is there any difference in TTFF time between them which are nrf_cloud_agps and AGPS using Google SUPL data?
