nRF52811 ADC resolution and enob
I am developing a custom board with nRF52811 where I will measure analog signals from op amp on ADC (single ended mode). Signals will be very small, so I need a good resolution. nF52811 and the board will operate on 1.9V supply, so I will need 12-bit resolution on ADC. This was actually the main reason for choosing nRF52 chip in the first place.
According to datasheet (SAADC Electrical Specification, page 281-282) the effective resolution (ENOB) is only 9bits, which is to low for me. There was already a similar topic on DevZone nRF52 ADC ENOB, but I still need some more clarifications regarding this topic.
  • According to datasheet 9-bits ENOB is for differential mode with 1/1 gain. What will be the ENOB for single ended mode and gain 1/3?
  • It was mentioned that the best ENOB for 12-bit can be 10.5bits (with oversampling), which is not much better for me compared with 10bit. What is ENOB for 10-bits (this parameter is missing in datasheet)?
  • What is VOS for 12-bits (this parameter is also missing in datasheet)?
Thanks for any help, Jure
    thank you for the reply.
    The understanding is much better now. Basically one cannot achieve better ENOB than 10.5-bit. I will try to include as much oversampling as possible and then see If I can achieve something better. I also assume that with 14-bit resolution things are exactly the same, because this is just a different format but the adc is still 12-bit?
    The signal I am measuring is actually not small. It is amplified (large gain used) by an op amp to achieve the whole possible voltage range on adc (1V8 with 1V9 power supply). This signal is static or very slowly changing and I also don't have problems with noise or other unwanted signals. The only problem is that even after amplification, the changes in signal are still small (~1mV on ADC), which I need to detect. Basically I need to be able to effectively detect each change of 1mV on ADC. And this can be challenging, especially because ADC itself is generating some internal noise, which is I guess larger then 1mV (when using 10.5-bit).
    Best regards, Jure
    Yes, from the feature list:
    • 8/10/12-bit resolution, 14-bit resolution with oversampling
    When doing oversampling, you can have averaging of n 14-bit values, where the 2 LSB are zero.
