Client to Server Data transmit
Hi every one , i tries to call the generic_onoff_client_set function to send a message from the client to the server but this ain't working. Can someone please help me?
Here is the code:
When i call the function, this is the error i get in the Logs:
Please help! Thank you all
    My answers below.
    Where do you call the code snippet above? And do you get the assert right away when calling generic_onoff_client_set function?
    I call the generic_onoff_client_set function in the main() loop. And i get the assert when i call the function.
    It would also be helpful if you sent me the call stack when the assert occurs.
    I call the function here. It is in the main loop.
    Can you also give me more details about your use-case? What are you trying to do?
    To explain, I'm trying to send a byte from the client to the server.
    That byte comes from a smartphone application connected to the client through the proxy service. This proxy service communication  works fine and I receive the byte in the client from the smartphone.
    When I receive the byte I have to retransmit it to the server. This is where I try to call the generic_onoff_client_set function in the main() but this is where I get the error.
    Is it clearer? Feel free to suggest another way to send data to the server if there is one.
    Thanks
    If you want to send a message from the smartphone to the server, then it's better if you just publish to the server's unicast address.
