nrf5 SDK IoT cannot ping nrf52840 from router
Hi!
I'm trying to do the TCP example with the nRF5_SDK_16.0.0_98a08e2, a nrf52840 DK board and a Raspberry Pi 3 B+ as a gateway but I got some problems.
For connecting the board to the Raspberry Pi I've followed the instructions from the tutorials (https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.iotsdk.v0.9.0/iot_getting_started.html?cp=7_4_2). My shell script derived from the tutorial looks like this:
#!/bin/sh
# Mount debugfs file system
mount -t debugfs none /sys/kernel/debug
# Load 6LoWPAN module
modprobe bluetooth_6lowpan
# Enable 6LoWPAN
echo 1 > /sys/kernel/debug/bluetooth/6lowpan_enable
# Set IPv6 forwarding
echo 1 > /proc/sys/net/ipv6/conf/all/forwarding
# Run Router-Advertisement Daemon (radvd)
service radvd restart
# Look for available HCI devices
# hciconfig
# Reset HCI device
hciconfig hci0 reset
# Read BLE-Address from nRF51
timeout 3s hcitool lescan
# Connect to the device
echo "connect 00:81:1D:38:22:71 1" > /sys/kernel/debug/bluetooth/6lowpan_control
sleep 3
# Add the IP prefix to the Bluetooth Interface bt0
ip address add 2001:db8::2/64 dev bt0
ifconfig bt0
# Restart radvd service
echo "ping the BLE device using the global address"
ping6 2001:db8:1::281:1dff:fe38:22:71 -c 5
Further, I have the following radvd.conf file:
interface bt0
    AdvSendAdvert on;
    prefix 2001:db8::/64
        AdvOnLink off;
        AdvAutonomous on;
        AdvRouterAddr on;
Now if I run the script, it is not possible to ping the nrf52840 board. The output I get is as follows:
bt0: flags=4161<UP,RUNNING,MULTICAST>  mtu 1280
        inet6 fe80::b827:ebff:fef5:2a08  prefixlen 64  scopeid 0x20<link>
        inet6 2001:db8::2  prefixlen 64  scopeid 0x0<global>
        unspec B8-27-EB-F5-2A-08-78-B3-00-00-00-00-00-00-00-00  txqueuelen 1000  (UNSPEC)
        RX packets 1  bytes 20 (20.0 B)
        RX errors 0  dropped 2  overruns 0  frame 0
        TX packets 12  bytes 1173 (1.1 KiB)
        TX errors 0  dropped 0 overruns 0  carrier 0  collisions 0
ping: 2001:db8:1::281:1dff:fe38:22:71: Name or service not known
Also, if I send an echo request to discover all devices that are currently attached to the RasPi router, I only get responses from the bt0 interface an no response from the BLE device:
sudo ping6 -I bt0 ff02::1
PING ff02::1(ff02::1) from fe80::b827:ebff:fef5:2a08%bt0 bt0: 56 data bytes
64 bytes from fe80::b827:ebff:fef5:2a08%bt0: icmp_seq=1 ttl=64 time=0.154 ms
64 bytes from fe80::b827:ebff:fef5:2a08%bt0: icmp_seq=2 ttl=64 time=0.147 ms
64 bytes from fe80::b827:ebff:fef5:2a08%bt0: icmp_seq=3 ttl=64 time=0.123 ms
Another observation that I made is that every time approximately after 30 seconds the nrf52840 BLE device loses its BLE connection.
My Raspberry Pi has kernel version 4.19.66-v7+ and runs Raspbian Stretch.
I tried changing BLE_6LOWPAN_LEGACY_MODE in the sdk_config.h from 1 to 0 (according to this post with a similar problem: https://devzone.nordicsemi.com/f/nordic-q-a/44801/nrf-sdk-iot-mqtt-publisher-example-can-t-ping-from-bt0-and-interface-go-down) but it didn't change anything.
Even if I simply run the given instructions (see below) from the tutorial I cannot ping the board.
#!/bin/sh
# Mount debugfs file system.
# Load 6LoWPAN module.
# Enable the bluetooth 6lowpan module.
# Look for available HCI devices.
hciconfig
# Reset HCI device - for example hci0 device.
sleep 2
# Read 00:AA:BB:XX:YY:ZZ address of the nRF5x device.
# Connect to the device.
sleep 3
# Check if you have established a connection.
ifconfig
# Try to ping the device using its link-local address, for example, on bt0 interface.
ping6 -I bt0 fe80::281:1dff:fe38:2271
When sending the ping to the link local address I do not get any response:
ping6: Warning: source address might be selected on device other than: bt0
PING fe80::281:1dff:fe38:2271(fe80::281:1dff:fe38:2271) from :: bt0: 56 data bytes
^C
--- fe80::281:1dff:fe38:2271 ping statistics ---
27 packets transmitted, 0 received, 100% packet loss, time 26620ms
I searched the Nordic forums a lot, but in almost every post that I found, people were at least able to ping the BLE board.
If maybe somebody experienced the same problem and could help me I would be very glad.
