As we are in design phase of our custom board based on nRF9160, can you please let us know what all pins needs to be exposed in our design for collecting modem traces?
regards
KK
regards
KK
Hi Simonr,
I did following changes but still unable to collect traces on UART2
1) added the below lines to the file ncs\v1.3.0\nrf\applications\serial_lte_modem\Kconfig
config BSD_LIBRARY_TRACE_ENABLED
bool "Enable proprietary traces over UART"
select NRFX_UARTE2
depends on BSD_LIBRARY
2) added tx and rx pins to the file ~\nrf\applications\serial_lte_modem\nrf9160dk_nrf9160ns.overlay
&uart2 {
current-speed = <115200>;
status = "okay";
tx-pin = <10>;
rx-pin = <11>;
3) enabled CONFIG_BSD_LIBRARY_TRACE_ENABLED=y in prj.conf file
did i miss anything?
regards
KK
Are you seeing any output at all on the TX and RX pins you've assigned to uart2? Please make sure that uart2 isn't defined multiple places in your project, as that might cause some conflicts.
Can you check that the NRFX_UARTE2_ENABLED and NRFX_UARTE_ENABLED defines are set to 1 in your project? Do you get any error codes or does the device run as expected?
Simon
I dont see any any data from the configured UART2 pins
I cant see the above mentioned macros in the autoconf.h but i do see CONFIG_NRFX_UARTE2 1, I think that should be ok
Anyway i am attaching the relevant files.serial_lte_modem.zip
I took a quick look at this and I think I figured out how to go about this.
I think the library bsd_os.c needs to be modified.
void trace_uart_init(void)
#ifdef CONFIG_BSD_LIBRARY_TRACE_ENABLED
/* UART pins are defined in "nrf9160dk_nrf9160.dts". */
const nrfx_uarte_config_t config = {
/* Use UARTE1 pins routed on VCOM2. */
//.pseltxd = DT_PROP(DT_NODELABEL(uart1), tx_pin),
//.pselrxd = DT_PROP(DT_NODELABEL(uart1), rx_pin),
.pseltxd = DT_PROP(DT_NODELABEL(uart2), tx_pin),
.pselrxd = DT_PROP(DT_NODELABEL(uart2), rx_pin),
.pselcts = NRF_UARTE_PSEL_DISCONNECTED,
If you've not changed the UART pins in an overlay file it will output it on the TX pin defined in ncs\v1.3.0\zephyr\boards\arm\nrf9160dk_nrf9160\nrf9160dk_nrf9160_common.dts
I have not tested this myself, but I think this is the way to go about it. Report back to me if it's working or not.
Bes regards,
Simon
One question: Do you want to forward the UART data to the USB port, such that it can get collected using the Trace Collector app, or are you collecting the data directly from the UART in some way?
