Running into a SIGTRAP, backtrace shows only main(), apparently happening in libgloss/arm/crt0.S
I'm using SDK v16 on an nRF52832 and occasionally run into a SIGTRAP with my custom application mainly forwarding BLE traffic from/to UART.
It works fine, only after quite a few interactions (can be 3 can be 30) - initiated by a BLE UART client running on Android - it stops being responsive.
Attached debugger (Black Magic Probe) provides me with the following output:
Starting program: /data/src/nrf5x-sdk-vanilla/projects/[..]/s132/armgcc/_build/nrf52832_xxaa.out
Program received signal SIGTRAP, Trace/breakpoint trap.
warning: while parsing target memory map (at line 1): Required element <memory> is missing
0x0002be5c in main ()
(gdb) l
1    ../../../../../../../../../libgloss/arm/crt0.S: No such file or directory.
(gdb) bt
#0  0x0002be5c in main ()
(gdb)
I'd be happy for any hint or idea. I could think of this being a arbitrary memory corruption. However I'm wondering about the SIGTRAP (not SEGV), libgloss/arm/crt0.S (no user code), as well as consistently ending up in this very state.
  • This comment is obsolete (while the actual issue still exists and is further discussed in the reply/replies after this one), but leaving it here for reference if somebody else is having issues with the Black Magic Probe and breakpoints not working:
    For the following code snippet:
              do
                ret = ble_nus_data_send(&m_nus, m_uart_buf[uart_buf_id], (uint16_t *)(&(m_uart_buf_pos[uart_buf_id])), m_conn_handle);
                if ((ret != NRF_ERROR_INVALID_STATE) &&
                    (ret != NRF_ERROR_BUSY) &&
                    (ret != NRF_ERROR_NOT_FOUND))
                  noop(ret);
                  APP_ERROR_CHECK(ret);
              } while (ret == NRF_ERROR_BUSY);
    I set a breakpoint in noop() via
    (gdb) break noop
    Breakpoint 1 at 0x370d6: file ../../../main.c, line 1568.
    (gdb) r
    but still end up in
    0x0002ce56 in app_error_fault_handler (id=16385, pc=225911, info=536936392) at ../../../../../../components/libraries/util/app_error_weak.c:100
    100	    NRF_BREAKPOINT_COND;
    (gdb) bt
    #0  0x0002ce56 in app_error_fault_handler (id=16385, pc=225911, info=536936392)
    addr2line still points to the "} while (ret == NRF_ERROR_BUSY);" line.
    What I can say, though, is, that removing the APP_ERROR_CHECK() call seems to make this issue go away. However this obviously isn't the solution. Also I wonder about why the breakpoint doesn't trigger. Compiled with -O0 and -DDEBUG. Also, GDB seems to see the noop symbol, so I'd say it's there.
    I went for the noop() instead of setting a breakpoint on APP_ERROR_CHECK() as GDB doesn't appear to see the macro:
    (gdb) break APP_ERROR_CHECK
    Function "APP_ERROR_CHECK" not defined.
    Make breakpoint pending on future shared library load? (y or [n]) y
    Breakpoint 1 (APP_ERROR_CHECK) pending.
    which makes sense, as it's not a symbol ending up in the binary.
    Setting a breakpoint on app_error_fault_handler also doesn't trigger a break, I still end up in NRF_BREAKPOINT_COND with a corrupt stack.
    For completeness here the definition of noop():
    void noop(uint8_t err_code) {
      UNUSED_VARIABLE(err_code);
    UPDATE: Neither does "break main" actually break on main() - so I assume that's a different issue.
    UPDATE 2: Ok, this appears to be a problem with the debugger I use - the Black Magic Probe. The issue was fixed in a later version, for reference and the record: https://github.com/blacksphere/blackmagic/issues/230
    Having breakpoints working now! Actual issue further investigated as part of the next comment.
  • Ok, so after having debugged and fixed the firmware of my debugger, back to the actual issue:
    When setting a breakpoint on app_error_fault_handler I get the following:
    Starting program: /data/src/nrf5x-sdk-vanilla/[..]/s132/armgcc/_build/nrf52832_xxaa.out
    Note: automatically using hardware breakpoints for read-only addresses.
    Breakpoint 1, app_error_fault_handler (id=16385, pc=225911, info=536936392) at ../../../../../../components/libraries/util/app_error_weak.c:58
    58	    __disable_irq();
    while the backtrace still looks messy:
    (gdb) bt
    #0  app_error_fault_handler (id=16385, pc=225911, info=536936392) at ../../../../../../components/libraries/util/app_error_weak.c:58
    #1  0x0002cce4 in app_error_handler (error_code=16385, line_num=225911, p_file_name=0x2000ffc8 "\226\006")
        at ../../../../../../components/libraries/util/app_error_handler_gcc.c:49
    Backtrace stopped: previous frame identical to this frame (corrupt stack?)
    (gdb)
    So I again went for the noop(), which results into the following code:
                  if(ret != 0)
                    noop(ret);
    resulting in:
    Starting program: /data/src/nrf5x-sdk-vanilla/sensorberg/projects/smartspaces/sdg03/s132/armgcc/_build/nrf52832_xxaa.out
    Breakpoint 1, noop (err_code=1 '\001') at ../../../main.c:1568
    1568	}
    having a seemingly not (yet) messed up stack:
    (gdb) bt
    #0  noop (err_code=1 '\001') at ../../../main.c:1568
    #1  0x00037266 in main () at ../../../main.c:1686
    So at that point we know that ble_nus_data_send() sometimes returns 0x01.
    Continuing execution now leads me right into the NRF_BREAKPOINT_COND with the corrupt stack:
    (gdb) c
    Continuing.
    0x0002ce56 in app_error_fault_handler (id=16385, pc=225917, info=536936392) at ../../../../../../components/libraries/util/app_error_weak.c:100
    (gdb) bt
    #0  0x0002ce56 in app_error_fault_handler (id=16385, pc=225917, info=536936392)
    #1  0x0002cce4 in app_error_handler (error_code=16385, line_num=225917,
        p_file_name=0x4001 "\211\240\201hh\200\211\340\201\233\346\020&O\360#\b")
    (gdb)
    So there's 2 questions now:
    a) why does ble_nus_data_send() sometimes returns 0x01?
    b) why does APP_ERROR_CHECK() /appear/* to end up with a corrupted stack?
    *obviously the actual root cause can be somewhere else and APP_ERROR_CHECK() only accesses memory already corrupted somewhere/-when before
  • a) Are you sure ret is actually 0x01 in this case? Here is the error codes that can be returned by sd_ble_gatts_hvx
    b) This will happen as the timing in the SD will be messed up when you halt at a breakpoint. i.e. the timers will continue to run and the event manager will be lost.
  • Re a) I don't know what else to tell from the GDB output, so yes, fairly sure
    Re b) it's the same corrupted stacktrace I get /without/ the breakpoint. See initial post (corrupted stacktrace without breakpoints set) and the one with breakpoints right after the break point in noop() is called only a line later. It's the same corrupted backtrace within APP_ERROR_CHECK(). Doesn't look like a co-incidence or GDB/breakpoint related (timing-)issue to me.
  • Are you able to recreate this issue on a nordic DK? and what hardware are you currently running your code on?
