A-GPS download fails mid session
I am trying to run the A-GPS sample program but am encountering a bit of difficulty with the SUPL code.
I had to modify the LTE connection code to allow access for NB-IoT, APN and User/Pass for the SIMs we are using but encounter this error during the connection and download process:
New AGPS data requested, contacting SUPL server, flags 59
Established LTE link
ip 4a7d:8cc0:: (c08c7d4a) port 7276
Starting SUPL session
ULP encoding length: 38
Bytes sent: 38
Bytes received: 34
ULP ossDecode success, choice 3
SUPL server responded using version 2.0.4
SUPL response received
ULP encoding length: 57
Bytes sent: 57
read again
Bytes received: 708
ULP ossDecode more input 4
Bytes received: 2996
ULP ossDecode success, choice 5
Failed to send AGNSS data, type: 1 (err: 5)
UTC conversion/injection failed, rc: 3
Generic assistance data injection failed, rc: 3
SUPL error: 2
ULP encoding length: 34
Bytes sent: 34
SUPL session internal resources released
SUPL session finished
Done
While building the sample program, I also was warned about an error in the SUPL code:
[38/138] Building C object modules/nrf/lib/supl/CMakeFiles/..__nrf__lib__supl.dir/os/lte_params.c.obj
/Users/xxxxxx/Downloads/ncs/nrf/lib/supl/os/lte_params.c: In function 'parse_lte_mcc':
/Users/xxxxxx/Downloads/ncs/nrf/lib/supl/os/lte_params.c:73:3: warning: implicit declaration of function 'memset' [-Wimplicit-function-declaration]
   memset(lte->mcc, 0, 3);
Could I get a bit of help decyphering what went wrong here? I have made no modifications to the SUPL code and only added code to enable connection to the Network in my local area.
	static const char     at_commands_NB[][50]  = {
					AT_CFUN_OFF,
					AT_XSYSTEMMODE,
	#ifdef CONFIG_BOARD_NRF9160_PCA10090NS
					AT_MAGPIO_LTE,
					AT_BANDLOCK,
					AT_APN,
					AT_USER_PASS,
					AT_ACTIVATE_LTE
static int activate_lte(bool activate)
	if (activate) {
		for (int i = 0; i < ARRAY_SIZE(at_commands_NB); i++) {
			if (at_cmd_write(at_commands_NB[i], NULL, 0, NULL) != 0) {
				printk("Error with at_commands_NB\n");
				return -1;
The above should be working correctly if the device was able to connect to the SUPL library in the first place so I doubt it's the above changes.
Many thanks,
MJD
