Tools and software versions that are required for developing BLE products with nrf51822 modules.
I have purchased an nRf52DK set for developing BLE applications. I am using the Segger Embedded Studio (SES) with GCC and SDK version 16 for development.
I have two questions:
1. I have a few nrf51822 modules that I bought a while ago.  Can I develop code for these modules in the setup that i have ? If not, could you please let me know the setup - Soft device version, SDK version and programmer that I will need to use these modules.
2. How can i check if these modules have a boot loader inside ? If that exists, can i program them over serial port and how to it?
Thanks and Regards
  • Hello Sreenivasa Chary,
    That is strange - I have not heard about this trouble when using the unmodified ble_peripheral_uart example before.
    Could you make sure DEBUG is defined in the preprocessor defines, as shown in the picture below, and run this again?
    This will let you know which error the bsp_init is being called with, so that we may see why the bsp_init failed.
    For future reference, this question is diverging from the original "Tools required for developing on the nRF51822" question, and I would recommend that you open a separate ticket regarding debugging of the ble_uart application, to keep the forum tidy.
    Karl
  • Hi Karl,
    Thanks for the inputs. Yes , i  will create a separate ticket for this issue.
    So i will close it here now and start a new post.
    But just for continuity, I have checked the settings and i see only DEBUG and DEBUG_NRF are specified in the Preprocessor settings. I will enable the other modules and see if i can get a log.
    Regards
    Chary BS
  • Hello Chary BS,
    Great, thank you for keeping the forum tidy.
    You will receive support for your issue in your new ticket.
    Karl
  • Hi Karl,
    Regarding the nRF51822 build, i followed the instructions in the link that you shared and also referred to the getting started guide. I was able to import the nrf51822 SDK12.3 SD130 version of ble_app_uart example, into my SES ver 4.30c (64-bit version) .
    I made the settings for the linker too, defining the section placements.
    However when i compiled the project, i get the following log from the Linker phase:
    1> Generating linker script ‘ble_app_uart_pca10028_s130.ld’
    1> Linking ble_app_uart_pca10028_s130.elf
    1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.30c/gcc/arm-none-eabi/bin/ld: Output/nrf51422_xxac/Exe/ble_app_uart_pca10028_s130.elf section `.init' will not fit in region `UNPLACED_SECTIONS'
    1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.30c/gcc/arm-none-eabi/bin/ld: region `UNPLACED_SECTIONS' overflowed by 32784 bytes
    1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.30c/gcc/arm-none-eabi/bin/ld: Output/ble_app_uart_pca10028_s130 nrf51422_xxac/Obj/SEGGER_THUMB_Startup.o: in function `exit':
    1> (.init+0x48): undefined reference to `__stack_end__'
    1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.30c/gcc/arm-none-eabi/bin/ld: (.init+0x4c): undefined reference to `__SEGGER_init_table__'
    1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.30c/gcc/arm-none-eabi/bin/ld: (.init+0x50): undefined reference to `__heap_start__'
    1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.30c/gcc/arm-none-eabi/bin/ld: (.init+0x54): undefined reference to `__heap_end__'
    1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.30c/gcc/arm-none-eabi/bin/ld: (.init+0x58): undefined reference to `__ctors_start__'
    1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.30c/gcc/arm-none-eabi/bin/ld: (.init+0x5c): undefined reference to `__ctors_end__'
    1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.30c/gcc/arm-none-eabi/bin/ld: Output/ble_app_uart_pca10028_s130 nrf51422_xxac/Obj/ses_nrf51_startup.o: in function `_vectors':
    1> (.vectors+0x0): undefined reference to `__stack_end__'
    1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.30c/gcc/arm-none-eabi/bin/ld: Output/ble_app_uart_pca10028_s130 nrf51422_xxac/Obj/ses_nrf51_startup.o: in function `SystemInit':
    1> (.init+0x64): undefined reference to `__SRAM_segment_end__'
    1> C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.30c/gcc/arm-none-eabi/bin/ld: Output/ble_app_uart_pca10028_s130 nrf51422_xxac/Obj/softdevice_handler.o: in function `softdevice_enable':
    1> softdevice_handler.c:(.text.softdevice_enable+0x28): undefined reference to `__data_start__'
    Build failed
    Any help possible ??
    Regards
    Sreenivasa Chary
  • There was one instruction int the getting started guide which said "Import Section Placement" but I coiuld not find that option in the menu. I did download the flash placement XML file and placed it in the project folder.
    I hope it is in the right place - i saved it  in the example folder for ble_app_uart.
    Regards
    Chary BS
