Thread protocol - one to many communication
We are considering using the Thread protocol for in an application where we have one or more central devices distributing data to several peripheral devices. However, it is important that the peripheral devices are saving power in between receiving messages. Therefore, we need to synchronize the peripheral devices and the central device(s) in order to preserve the maximum amount of power. Thus, strategies such as mesh routing would not work since the peripheral devices won't necessarily be awake at the same time. Therefore, we need to use the Thread protocol in a one-to-many messaging strategy, perhaps utilizing a second central device for relaying messages to the peripheral devices.
Is this possible to achieve with Thread, or are there som other protocol more suitable for our application?
  • Thank you for your answer.
    A typical network will consist of about 30-50 nodes. Two (or perhaps three) of these will be connected to a constant power source and do not require any power saving. Thus, I reckon we could use those as routers. The other nodes may use battery power and should, in that case, save as much power as possible. All of these nodes are scattered around an area of maybe 25 * 3 m2 - with some thin walls and stuff in between.
    I am curious about the parent-polling you mentioned. For the record, our end devices are not going to send data to the parents; they are going to receive data from the parents, and, depending on the received data, e.g. signal something. Since we are planning to make the end devices sleep as much as possible, my initial thought was that this could be a problem, since we need to synchronize (using a RTC, which drifts?) the end devices with the parents. Could you elaborate more around this parent-polling scheme (or in this case, parent-pushing) and how to synchronize these devices? And if there are some caveats about this set up we are not thinking about, I would be glad to hear about them.
    There is no need for synchronization in the application, this is handled by the stack during child to parent attachment. The parent/router will have the radio in RX mode, whenever it does not transmit, being ready to receive packets from the child nodes and/or other routers. The child node will use the indirect transmission method to check for incoming data from the parent at the set poll interval. If the ack from the parent indicates no pending data, the SED node can go back to sleep. The parent needs to store incoming packets for all its associated children. For more details, I would recommend you to read chapter 4.7 in Thread 1.1.1 specifications about "Network Attaching".
  • Thank you for your answer, that is good news.
    However, let's say the network has 30-50 End Devices which are regularly polling a parent for information (each minute). Would it be advantageous to configure the End Devices such that the are polling at different time intervals? If so. how can this be achieved without any synchronization?
    Update: Could any network congestion occur with 30-50 End Devices polling from a Router that often - at the same time? Whenever new data is present, I reckon the package size would be around 30-50 bytes.
    Furthermore, approximately for how long does the End Device need to activate its radio for polling data each time when:
    - There are no new data
    - There are new data of maybe around 30-50 bytes
    I need to make an estimate of power consumption.
    Also, about the Border Router, our plan is to use a Thingy91-like device for connecting to LPWAN protocols. Thus, a device which integrates both nRF9160 and nRF5240. This device will receive som data over LPWAN; transfer it to the nRF52840 (Router) and distribute it further to polling End Devices. Are there some caveats about this set up we are not thinking about? Do we even need to think about the Border Router role in this setup? To me, it sounds like we have created an alternative Border Router by using a Thingy91-like device.
    Update: I forgot to ask, on https://openthread.io/guides/thread-primer/node-roles-and-types, the Border Router is not connected to any End Devices. I reckon End Devices easily could be connected to a Border Router?
  • Also, if we have e.g. two Routers communicating with a set of End Devices (half of them, in that case), what happens if one of the Routers malfunction? Could the End Devices communicating with that Router automatically connect to the operating Router and continue its operation?
    I'm not aware of any ready-made synchronization mechanisms for this, it must be implemented on the application layer if you find it necessary in your network. Thread implements Carrier Sense Multiple Access - Collision Avoidance (CSMA-CD) and uses Clear Channel Assessment (CCA) with energy detection to check for on-air activity before transmitting. If it detects other transmitting devices, it will do a backoff before retrying.
    See page 6 of this whitepaper from the Thread group.
    I have previously done some measurements for some similar use-cases on the nRF52840, I have copied the results here as it may be useful for your power estimations:
    I recently did some measurements for another customer for a similar use-case with nRF52840 (+8 dBm output power and DCDC regulator enabled, 3.0 V supply voltage). Here are some of the results:
    Activity Average current [µA] Activity duration [µs]
    Sleep/Idle (Full 256 kB RAM retention) 3.5 N/A
    Sleep/Idle (96 kB RAM retention) 2.2 N/A
    Parent poll interval (0-byte RX data, 0 dBm) 2400 5.85
    Parent poll interval (0-byte RX data, +8 dBm) 3800 5.85
    Parent poll interval (28-byte RX data, 0 dBm) 4700 10
    Parent poll interval (28-byte RX data, +8 dBm) 6700 10
    10-byte TX 9100 3.6
    The commissioning phase will depend on the commissioner, which in most cases are unknown. I did two tests with the nRF52840 and nRF52833 as commissioner:
    • Fast commissioner (nRF52840 with HW crypto-engine) - approximately 6.5 mA average current for ~8 seconds
    • Slow commissioner (nRF52833 with SW crypto-engine) - approximately 6.8 mA average current for ~30 seconds
    DFU will depend on the image size and parent poll interval. I did two tests for this as well, with a 300 kB image:
    • 1000 ms parent poll interval - approximately 150 µA average current for ~4520 seconds
    • 100 ms parent poll interval - approximately 940 µA average current for ~721 seconds
    Note that all there measurements are taken in a clear environment. High on-air traffic will occasionally cause retransmissions and increased current consumption.
    If you do not need IPv6 connectivity to the end node, there is nothing preventing you from using another type of gateway than the specified border router solutions. The responsibility of the border router role is to forward packets between the thread network and another network (typically Ethernet/WiFi). It does not normally do packet processing/translations, even though such features can be implemented in a border router as well (one example is the MQTT-SN gateway that we run on our Border Router solution).
    Yes, the border router is an FTD, which operates in a router/leader role. It can have children attached like any other router.
    Yes, a Thread network is a self-healing network with no single-points of failure. If one router goes down, the children will try to attach to other routers within range. However, you need to make sure that the other router is capable of attaching that many devices and that the router is within range of all the end nodes.
