Hardfault error in porting Thead example (with SoftDevice) from PCA10056 to PCA10059
I notice that Thread examples with Softdevice (nRF5_SDK_for_Thread_and_Zigbee_v4.0.0_dc7186b) works fine for a PCA10056 but not on a PCA10059.
When I had tried to make this exemples works for a PCA10059 (following the instructions given here "https://devzone.nordicsemi.com/nordic/short-range-guides/b/getting-started/posts/nrf52840-dongle-programming-tutorial" - replace BOARD_PCA10056 to BOARD_PCA10059 in preprocessor definitions), it never worked: once the device programmed (with nRF Connect), nothing happened.
Jørgen Holmefjord  confirmed me that there are a problem... This was his reply (ticket at devzone.nordicsemi.com/.../porting-ble_thread_dyn_mtd_coap_cli-from-pca10056-to-pca10059):
"I did a test with the latest SDK version, by changing BOARDS_PCA10056 to BOARDS_PCA10059, but I'm not able to run it on the dongle. It seems to run fine on the nRF52840 DK however. I think this is related to the lack of a UART port on the dongle, and/or GPIO config for LEDs and button(s). I will try to make a working version of the application for the dongle.
I did some more testing on this today, but it seems I always get a Hardfault in softdevice area when the OpenThread libraries are initialized on the Dongle. I did manage to run the application on a dongle that I erased and programmed through the debug-header, but I cannot get it to work with the bootloader present. I would highly recommend you to get a DK to do the development on, as the dongle does not provide good debug-capabilities."
In fact, when I comment out the Thread part in the example "ble_thread_dyn_mtd_coap_cli_pca10056_s140", the program runs correctly in a pca10059. However, if the OpenThread is  enabled, this example does not work on the pca10059.
For your information, I had to modify the flash_placement.xml file so that the "start_ot_flash_data" address is 0xE0000 instead of 0xFC000 (because if I use this example with the bootloader (the bootloader is between the addresses 0xE4000 to 0xFE000), the Thread and the bootlaoder use the same addresses). Doing this allows you to run this example with the bootloader on a pca10056 but does not yet solve the problem for a pca10059.
I have 3 DK boards and 20 dongles. My application was completely developed on the DK but I would like to incorporate it into the dongles to simulate a Thread network and use my features (I don't need the UART on the dongles). So that's why I need to be able to operate the dongle with my app.
Could you look at why there is a problem when using this example in a pca10059?
Thank you
    That was not entirely the purpose in my response. Did you try to run add a bootloader on the nRF52840 DK and run your application there? That would reveal if it is in fact a hardfault because of the bootloader or not. To make it even more similar to the dongle, do this while running the pca10059 project on the DK. Also, remember to not initialize the UART CLI when running on the dongle, unless you have actually attached those pins to a UART interface. You can simulate the error you would get on the dongle on a DK by changing the UART pin numbers to pins that aren't connected to anything, and then short the RX pin to GND and VDD a couple of times. You will see that your application will run into the COMMUNICATION_ERROR event quite rapidly, because the UART peripheral can't make sense of the "incoming UART message".
    Edvin said:
    If you suspect the UART pins to be the issue, then you can try to ground the UART RX pin, P0.08 on the dongle. Alternatively, comment out the UART functions (at least the COMMUNICATION_ERROR event. Or you can try to simulate a floating RX pin on the DK by using a breadboard wire to pull it high and low (short it to VDD and GND) and see what happens.
    But please remember that the UART is not routed through a debugger on the Dongle, as it is on the DK, so you will not be able to use it with a terminal. The dongle's USB port is the USBD peripheral on the nRF52840, so it doesn't have any nRF -> UART -> PC functionality, unless you have an external UART -> USB device (which is usually the programmer on the DK).
  • Hi Edvin,
    Here are the tests I performed:
    - I compiled my project for pca10059 (also bootlaoder) and I executed the project on pca10056: everything works fine without errors
    - I used nrf Connect to program the pca10059 with this same project (app + softdevice): I don't see my device on the nrf connect of my smartphone
    - I compiled my project but by commenting the initiation of the Thread network and I run it on the pca10059: it works, I can see my device on the nrf connect of my smartphone
    So there is a problem caused by the Thread part when it is executed on the pca10059.
    To find out where the error is, I started by commenting out the entire Thread part and seeing if I see the device in Bluetooth: yes
    Then, I uncommented line by line to see from which line I could no longer see my device in Bluetooth. Apparently, the following code is the problem in pca10059:
    mp_ot_instance = otInstanceInitSingle ();
    ASSERT (mp_ot_instance! = NULL);
    Do you have any idea what could be causing this error?
    Here is my config:
    FLASH_PH_START=0x0
    FLASH_PH_SIZE=0x100000
    RAM_PH_START=0x20000000
    RAM_PH_SIZE=0x40000
    FLASH_START=0x27000
    FLASH_SIZE=0xd5000
    RAM_START=0x20002ae8
    RAM_SIZE=0x3d518
    Flash_placement.xml:
    <MemorySegment name="ot_flash_data" start="0xE0000" size="0x4000">
    <ProgramSection alignment="4" keep="Yes" load="Yes" name=".ot_flash_data" address_symbol="__start_ot_flash_data" end_symbol="__stop_ot_flash_data" start = "0xE0000" size="0x4000" />
    </MemorySegment>
    I used the example ble_thread_dyn_mtd_coap_cli_pca10056_s140(from nRF5_SDK_for_Thread_and_Zigbee_v4.1.0)
  • I wasn't aware, but the bootloader on the dongle is larger than the SDK ble bootloader. It reaches from 0xE 0000 -> 0x10 0000.
    I adjusted all the settings in the attached project file. I removed the build folders to keep the size small.
    Try it out. It advertises as Thread_UART on my desk.
    You can use the merge_app.bat file in ble_thread_dyn_mtd_coap_cli\pca10059_t\s140\ses to merge the application with the softdevice.
    ble_thread_dyn_mtd_coap_cli.zip
    The project you want to test is the pca10059_t\ses project.
    Please note that this is not an official Nordic release. Delivered as is.
    BR,
    Edvin
  • So it was the project configuration that was problematic. Now it works Slight smile
    Thank you so much
