Connection Parameter Selection for Central Device with 10 Peripheral Simultaneous Connections
I am developing both Central and Peripheral devices with nRF52840. For consistency, both are using SDK 15.3.0 and S140 V7.
I am able to connect to peripherals and negotiate MTU ATT size of 247 and I am able to negotiate 2 Mbps phy. Logging on both peripheral and central devices confirm this is working.
My challenge is getting notification data from my peripherals to my central. If I set up (for example) 2 peripherals to notify my central device every 500 mSec with approx 160 bytes of data, all data comes into the BLE event handler (BLE_GATTC_EVT_HVX) within my central device just fine. If I double the data speed on peripherals (ie. 160 bytes every 250 mSec from each of the 2 devices), I only get BLE_GATTC_EVT_HVX events notifying me of incoming data from the first peripheral only.
I believe that I am not getting correct connection service intervals setup after peripheral connection.
For a scenario where a central is talking to 10 peripherals and getting notification data from each every 250 mSec, what would good connection interval, slave latency values be? I cannot seem to find a good reference for setup of connection intervals for multiple simultaneous peripheral connections to a central device - where each peripheral is notifying the central independently.
Note that my connection event length is 6 x 1.25 mSec or 7.5 mSec. This should be plenty long enough to get an MTU of 247 bytes transferred.
I have been using default min and max connection intervals of 7.5 and 30 mSec respectively and a slave latency of 0 (for both central and peripheral devices).
Suggestions for my scenario would be much appreciated.
Thanks in advance,
Mark J
  • Yes. The issue appears to be that I am lacking data from devices. I have sent the same data slower and I receive all data. For example, If I send 160 bytes every second, I get all data.
    When I go faster, notification data only comes in from 1 of 2 connected peripherals. As I am using notifications, I am not making hvx calls.
    I had suspected that the issue related to a scan window interrupting my connection events, but if I am NOT CURRENTLY SCANNING, I think that the scan window will not affect connection event servicing. Is this true?
    If I setup a connection scan window (say 100 mSec) and a connection interval of 120 mSec and I am not scanning, will there be any effect on connection event servicing and the ability for peripherals to notify me of data changes?
    I do not need to scan when getting notification data from peripherals. I will scan, connect, then get data.
    Mark J
  • BLE is a lossless protocol (ensured by ACKing and retransmission), so scanning shouldn't affect this. As long as you are not disconnected, all packet should arrive eventually, and in the same order as you send them.
    Perhaps you can show me how you are sending the data where you see the loss?
    You are still using SDK15.3.0, right? The reason I ask is that from SDK16.0.0 they did something to the ble_nus_c_string_send() which in my opinion makes it unreliable. The 15.3.0 implementation of this should be good.
  • Was off until today.
    If scanning interrupts connection events  and these events back up, eventually there must be losses at the app level. This Nordic page (and others) are pretty clear about how connection events can be affected by scanning: Suggested intervals and windows.
    Since sending my last comment, I have tried setting very small scanning windows and this has not improved throughput.
    As stated in our last post and this post, we are not using NUS anymore. We are now able to use the underlying api support to get connection handles and reference connections using these handles. NUS did not give us access to handles. This is all described in the last post. This code is working fine if we have slow data updates (2 peripherals notifying us every 500 mSec with 160 bytes of data). The issue is if these peripherals notify at 250 mSec freq (160 bytes), we can miss data from 1 of the 2 peripherals (all notifications from that peripheral).
    Please re-read the top of this post as it clarifies how we are sending data.
    Yes, still using SDK 15.3.0, but as stated not NUS.
    Could the be related to the code servicing BLE notifications not getting enough bandwidth? My main loop is in an earlier post in this thread. Empirical testing shows that loop time is < 10 uSec, so I would expect that this is fast enough.
    Would it be faster to poll peripherals instead of their using notifications to send the central data? This seems counter-intuitive, but we need to get a solution quickly. We have customers waiting for our device firmware with support for 10 peripherals and this is the last hurdle to completion.
    Mark J
     I am sorry for mixing up. Please remember that we handle many cases every day, so when there are days between looking at a ticket, I sometimes forget details.
    The ble_nus_c.c file doesn't forward the connection handle to the event handler. This can easily be fixed by adding:
    ble_nus_c_evt.conn_handle = p_ble_evt->evt.gattc_evt.conn_handle;
    in on_hvx() in ble_nus_c.c. But I'll stop nagging about this now. Just in case you wondered why.
    Can you check that the peripherals that are sending this data is calling  sd_ble_gatts_hvx(), and that this returns NRF_SUCCESS on the data you claim to be missing?
    Note that if the peripheral is never actually getting the data through, then the continuous calls to sd_ble_gatts_hvx() will eventually return NRF_ERROR_RESOURCES, before disconnecting.
    Have you tried to sniff the connections? Can you see the data from both devices over the air? The nRF Sniffer should be sufficient for this sniffer trace. You can only sniff one connection at the time, so try to sniff the connection that you don't see the data from.
    Edvin
  • Hi ,
    I apologize if I sounded unappreciative with my note about NUS. I appreciate the assistance.
    I am using APP_ERROR_CHECK(err_code) to check the response from each sd_ble_gatts_hvx() call and I am not seeing anything other than NRF_SUCCESS.
    I added some logging around the update of connection parameters and learned that my peripherals were  not letting my central drop the connection interval as low as expected. I can change this as required. The issue is that the peripheral min connection supported is too high.
    I also have found and fixed a bug in my peripheral code that lead to too few sd_ble_gatts_hvx() calls. That very likely (to be confirmed with more testing) addressed the Bluetooth notification issue. I am now struggling with a USB device comms issue (likely my bug or a LInux CDC driver issue).
    I will need more time to dig into and fix the USB issue before properly testing the Bluetooth notification fix.
    Mark J
