Failed to Start Application after DFU - Blinky App repeatably loads fine
I continue to successfully upload the Blinkey app via DFU.  However, when I attempt to upload my development app it does not start.  From what I read it has successfully loaded the app.
I'm not sure I fully understand the RTT readout - Could it be related to the starting address?  If so, how can that be properly determined and modified in the code.
Otherwise, assistance pointing me in the right direction would be appreciated.
DFU Setup Specifics:
  • Bootloader Application: SDK16.0\examples\dfu\secure_bootloader\pca10040_s132_ble_debug
  • nRF52 DK (nRF52832)
  • Segger IDE / Windows 10
  • nRF Connect Windows10 - used for DFU zip file transfer
Short output from RTT file.  End of DFU and output after restart of nrf52DK:
................. (Started at the end of the file - full file is attached)
<debug> nrf_dfu_ble: Buffer 0x200083A4 acquired, len 60 (244)
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (data)
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000682DC, src=0x200083A4, len=60 bytes), queue usage: 1
<debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
<debug> nrf_dfu_flash: Flash write success: addr=0x000682DC, pending 1
<debug> nrf_dfu_ble: Freeing buffer 0x200083A4
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (data)
<debug> nrf_dfu_req_handler: Offset:271128, CRC:0x012B49C3
<debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (data)
<debug> nrf_dfu_req_handler: Whole firmware image received. Postvalidating.
<debug> nrf_dfu_validation: Hash verification. start address: 0x26000, size: 0x42318
<debug> nrf_dfu_validation: Invalidating old application in bank 0.
<debug> nrf_dfu_settings: Writing settings...
<debug> nrf_dfu_settings: Erasing old settings at: 0x0007F000
<debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007F000, len=1 pages), queue usage: 1
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007F000, src=0x2000934C, len=896 bytes), queue usage: 2
<info> nrf_dfu_settings: Backing up settings page to address 0x7E000.
<debug> nrf_dfu_settings: Erasing old settings at: 0x0007E000
<debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007E000, len=1 pages), queue usage: 3
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007E000, src=0x200096CC, len=896 bytes), queue usage: 4
<debug> app: timer_stop (0x20005984)
<debug> app: timer_activate (0x20005984)
<debug> nrf_dfu_flash: Flash erase success: addr=0x0007F000, pending 4
<debug> nrf_dfu_flash: Flash write success: addr=0x0007F000, pending 3
<debug> nrf_dfu_flash: Flash erase success: addr=0x0007E000, pending 2
<debug> nrf_dfu_flash: Flash write s<info> app: Inside main
<debug> app: In nrf_bootloader_init
<debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
<debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
<debug> nrf_dfu_settings: Using settings page.
<debug> nrf_dfu_settings: Copying forbidden parts from backup page.
<debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping.
<debug> app: Enter nrf_bootloader_fw_activate
<info> app: No firmware to activate.
<debug> app: App is valid
<debug> nrf_dfu_settings_svci: Erasing settings page additional data.
<debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007E000, len=1 pages), queue usage: 0
<debug> nrf_dfu_flash: Flash erase success: addr=0x0007E000, pending 0
<debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007E000, src=0x200096CC, len=896 bytes), queue usage: 1
<debug> nrf_dfu_flash: Flash write success: addr=0x0007E000, pending 0
<debug> app: Running nrf_bootloader_app_start with address: 0x00001000
<debug> app: Disabling interrupts. NVIC->ICER[0]: 0x0
// Power Down and back up -
00> <info> app: Inside main
00> <debug> app: In nrf_bootloader_init
00> <debug> nrf_dfu_settings: Calling nrf_dfu_settings_init()...
00> <debug> nrf_dfu_flash: Initializing nrf_fstorage_nvmc backend.
00> <debug> nrf_dfu_settings: Using settings page.
00> <debug> nrf_dfu_settings: Copying forbidden parts from backup page.
00> <debug> nrf_dfu_settings: Destination settings are identical to source, write not needed. Skipping.
00> <info> nrf_dfu_settings: Backing up settings page to address 0x7E000.
00> <debug> app: Enter nrf_bootloader_fw_activate
00> <info> app: No firmware to activate.
00> <debug> app: App is valid
00> <debug> app: Running nrf_bootloader_app_start with address: 0x00001000
00> <debug> app: Disabling interrupts. NVIC->ICER[0]: 0x0
Thank you to Hung Bui who help me out on a previous question.
Peter
DFU_LOG070220.txt
  • Thanks for the tip David. It's actually very useful so we don't have to modify the bootloader when in development.
  • Hung - I hope your vacation was pleasant.
    I'm up to speed now being able to create the setting hex file and merge with the bootloader, softdevice and application.  Note that I had to setup the nrfutil string to read:
    nrfutil settings generate --family NRF52QFAB --application AppDFUTest.hex --start-address 0x0007F000 --no-backup --application-version 0 --bootloader-version 0 --bl-settings-version 2 setting.hex
    This works and is consistent. I don't exactly understand the need for the
    component: --no-backup (you may comment on this)
    And I needed to add --start-address 0x0007F000 because the default boot start address
    was not correct.
    Next up is incorporating the "buttonless" components into my application.
    Stay Tuned!!!
    Thanks Again,
    Peter
  • Thanks Peter.
    The --no-backup is to not overwriting the backup area of the bootloader setting. This doesn't take any effect if you are testing on a blank chip with no backup setting prior.
  • Hung - The DFU continues to work albeit with one concern.  This may be related to the nRF Connect tool and I've I had limited success finding a solution on the web.
    When initiating a DFU with my device via nRF Connect (Windows 10 - nRF Connect version 2.4.0 nRF Engine 3.4.1)
    nRF Connect connects fine to the device and I'm able to select a zip file to DFU.  After selecting start DFU nRF Connect disconnects with the device (which may be normal.)  It then takes two minutes before the transfer begins, I believe initiated by nRF Connect.  Looking at the current draw during this two minutes I can assume the device is idle ans possibly waiting for nRF Connect.
    Once the transfer is complete the device works as expected.
    My question is where is the two minute delay coming from - is it nRF Connect or can I modify my code to decrease the delay?
    As a side note I'm starting out developing a raspberry pi 4 application to perform this task, hoping to utilize existing code samples (TBD)
    As always - thank you for your assistance!
    Peter
  • Hi Peter,
    Sorry for the late response. nRF Connect disconnect with the device is normal. It's when the device switch from application to DFU mode. But 2 minutes delay is high. We need to check if it was the board didn't switch to the bootloader right away or it's because nRF Connect didn't establish a new connection.
    You can check this by capture a sniffer trace. Or you can also use a phone to scan and check if the device is advertising as "DFUTarg" after disconnect from nRF Connect.
    I would suggest to test with stock example (stock bootloader + stock buttonless application) to see if it has the same behavior.
