Custom AGPS: Which data is required for the AGPS?
I'm currently implementing AGPS on 9160, nrf connect master branch.
Right before every GPS search we are connecting to our own server via CoAP.
To minimize data usage and power consumption I want to avoid using the SUPL library.
Instead I'm returning approximate coordinates and a timestamp from our server to the device, and I'm trying to feed it to the AGPS.
As there is no documentation for the gps driver I've been digging around in the code.
I've found a few data structures that I can send to the driver, but they all have quite a lot of extra data that I'm not sure is required or not.
The struct called nrf_gnss_agps_data_location_t seems to be the one I need, but it doesn't just have latitude+longitude, it has orientations and uncertainty etc.
Are all of those data points in the same struct necessary?
For instance, can I just use 0x00 or 0xff for some data points I don't have?
Also, should I load the AGPS with all the different types of structs as well?
Does some of the structs make other structs irrelevant?
For instance, should I load the agps with ephemeris, almanac and location, or would just location be enough?
Bonus questions:
Do you have any examples of, or documentation regarding using AGPS through the GPS driver without the SUPL library?
What is the data usage and power consumption cost of using the SUPL library?
Am I crazy for rolling my own solution instead of just using it?
  • Hi, we are still waiting for answers to Simon's questions internally, but I'll try to add my knowledge here as well.
    When it comes to what data is necessary, the answer is the more, the better.
    However, the data has different longevity, so not all the data is necessary every time.
    E.g. the almanac is valid for weeks (I don't remember the exact number at the moment) but can be used for months with less performance gain. In addition, it is not strictly necessary, so the GPS should be able to get a fix even if it is missing.
    Meanwhile, the ephemeris is only valid for a couple of hours, before it must be refreshed.
    So, I would say that if you fill out what you can, that should help you a bit. However, this is mostly (somewhat qualified) speculation on my part. It might be that the whole struct must be filled (correctly) for you to get any benefit.
    When it comes to the data format, I have seen any specifications, though I would assume it is closely related to the format used by the satellites. The format of the structs is probably specific to the nRF9160, but the data inside should be fairly standard.
    I do not believe that any of the structs make any of the other redundant.
    If you haven't already, you should take a look at the A-GPS related files in the nrf_cloud library (nrf/subsys/net/lib/nrf_cloud), which shows how that library handles requesting and downloading A-GPS data from nRF Cloud.
    Didrik
