nrf_pwr_mgmt.c:78: undefined reference to `__start_pwr_mgmt_data' when using pwr management
Hello everyone, I am running a code with uart i2c interruption and power management but I have this error : nrf_pwr_mgmt.c:78: undefined reference to `__start_pwr_mgmt_data'
I already try to copie some code in the linker script but it doesn't work. Maybe I am doigt it wrong.
Thank you have a good day !
best regards,
Arnaud
  • Is the Power Management module enabled in the SDK config file?
  • I'm hitting this problem too. Likely it is some dependency of the pwr_mgmt library that I haven't yet been able to find.
    SDK: 17.0.2; IDE: Segger SES
    I have already added the following files to my project:
    components/libraries/pwr_mgmt/nrf_pwr_mgmt.c
    components/libraries/experimental_section_vars/nrf_section_iter.c
    And these include paths in Preprocessor - User Include Directories:
    components/libraries/mutex
    And enabled the following in sdk_config.h:
    NRF_PWR_MGMT_ENABLED
    NRF_SECTION_ITER_ENABLED
    Anybody got an answer for this?
  • Well, here's the answer. Looks like this problem is specific to using SES IDE. How would any developer be expected to know this!!
    A similar DevZone post about "undefined reference to '__fs_data_load_start__' " led me to suspect the flash_placement.xml file. Comparing that file in my project to the one in examples/peripheral/pwr_mgmt/ gave the solution.
    In file flash_placement.xml, the following line is needed (it should be after the name=".text" line):
     <ProgramSection alignment="4" keep="Yes" load="Yes" name=".pwr_mgmt_data" inputsections="*(SORT(.pwr_mgmt_data*))" address_symbol="__start_pwr_mgmt_data" end_symbol="__stop_pwr_mgmt_data" />
    Apparently, not all the example projects include this line (my project started with the blinky example).
