Hi Einar,
thanks for the hint. By trying to follow it, I get trapped by secure service causing a crash.
And I have other problem too: I want to print out the created keys to the console with
mbedtls_pk_write_pubkey_pem and mbedtls_pk_write_key_pem but they need
MBEDTLS_PK_WRITE_C to be defined, which needs a specialized mbedtls config file.
(At least I have not found a Zephyr Kconfig macro to accomplish this.)
How can I create and use such a config file without messing up Nordic's mbedtls configuration?
Árpád
Hi Árpád,
PopradiArpad said:thanks for the hint. By trying to follow it, I get trapped by secure service causing a crash.
I see. Have you applied the workaround?
PopradiArpad said:How can I create and use such a config file without messing up Nordic's mbedtls configuration?
I have not had a chance to test this myself, but I would not expect setting MBEDTLS_PK_WRITE_C in the mbedTLS config header file would mess up anything? In what way does it cause problems?
Einar
Hi Einar,
thank you for your answer!
to mbedTLS configuration:
It's really much easier to configure mbedTLS directly by an mbedTLS config file then through the predefined Zephyr config symbols. The only tricky part was having that file within my project.
But this prj.conf snippets does it:
# Generate credentials CONFIG_MBEDTLS=y # Configure mbedTLS directly with its configuration file instead through Zephyr config symbols # Relative from ncs/modules/crypto/mbedtls/configs/config-tls-generic.h CONFIG_MBEDTLS_CFG_FILE="../../../../MY-PROJECT/config-tls.h"
Writing the config file is easy: all the missing mbedTLS config definitions are checked by mbedTLS itself
during compilation or in case of a link error it's easy to find by the guard macro name.
to the secure service causing crash:
later.
Árpád
Hi Einar,
your workaround works like a charm :)
Here is step by step how to generate EC 256 key pair. (X509 certificate is not needed by Google Cloud IoT)
For nRF Connect SDK v1.3.0
1. Apply the needed pieces of workaround :
secure_services.h
// https://devzone.nordicsemi.com/f/nordic-q-a/63576/nrf91-how-is-it-possible-to-generate-ec-256-key-pair-and-a-self-signed-x-509-certificate https://github.com/nrfconnect/sdk-nrf/pull/2519/files
#include <zephyr.h>
//int spm_request_random_number(u8_t *output, size_t len, size_t *olen);
static inline int spm_request_random_number(u8_t *output, size_t len, size_t *olen);
int spm_request_random_number_nsc(u8_t *output, size_t len, size_t *olen);
k_sched_lock();
int err = spm_request_random_number_nsc(output, len, olen);
k_sched_unlock();
return err;
secure_services.c
int err;
if (len != MBEDTLS_ENTROPY_MAX_GATHER) {
return -EINVAL;
err = mbedtls_hardware_poll(NULL, output, len, olen);
return err;
2. Add mbedTLS support in prj.conf:
# Generate credentials # Based on # ncs/zephyr/samples/net/cloud/google_iot_mqtt/prj.conf # ncs/iluminate-hub-nrf9160/build_nrf9160dk_nrf9160ns/mcuboot/zephyr/.config CONFIG_MBEDTLS=y CONFIG_MBEDTLS_BUILTIN=y # Configure mbedTLS directly with its configuration file instead through Zephyr config symbols # Relative from ncs/modules/crypto/mbedtls/configs/config-tls-generic.h CONFIG_MBEDTLS_CFG_FILE="../../../../iluminate-hub-nrf9160/config-mbedtls.h"
3. Configure mbedTLS by an own mbedTLS config file based on ncs/modules/crypto/mbedtls/configs/config-tls-generic.h and positioned in the project directory.
I named it config-mbedtls.h.
//Changes relative to ncs/modules/crypto/mbedtls/configs/config-tls-generic.h //---------------------------------------------------------------------------------- // general settings #define MBEDTLS_ERROR_C // for printing mbedTLS keys and certificates #define MBEDTLS_PEM_WRITE_C #define MBEDTLS_PK_WRITE_C #define MBEDTLS_BASE64_C // for key generation #define MBEDTLS_PK_C #define MBEDTLS_ECP_C #define MBEDTLS_ECP_DP_SECP256R1_ENABLED #define MBEDTLS_OID_C #define MBEDTLS_ASN1_WRITE_C
4. The C code
#include "secure_services.h"
#include "mbedtls/ecdsa.h"
#include "mbedtls/pk.h"
#include "mbedtls/error.h"
#include <logging/log.h>
LOG_MODULE_REGISTER(credentials, CONFIG_ASSET_TRACKER_LOG_LEVEL);
// The generated random number has fix 144 length. See doc of spm_request_random_number
#define GENERATED_RANDOM_NUMBER_LENGTH 144
// See mbedtls_entropy_func as example
static int gen_true_random_number(void *unused, unsigned char *output, size_t len )
// spm_request_random_number uses uint8_t and not unsigned char
__ASSERT(sizeof(unsigned char) == sizeof(uint8_t), "Adapt type!");
if( len > GENERATED_RANDOM_NUMBER_LENGTH )
LOG_ERR( "Max generatable real random number length exceeded");
return -1;
static uint8_t rnd_number[GENERATED_RANDOM_NUMBER_LENGTH];
memset( rnd_number, 0, GENERATED_RANDOM_NUMBER_LENGTH);
size_t rnd_number_length = 0;
int err = spm_request_random_number(rnd_number, GENERATED_RANDOM_NUMBER_LENGTH, &rnd_number_length);
if( err != 0 )
LOG_ERR( "Can't get real random number: %d", err);
return -1;
if( rnd_number_length < len )
LOG_ERR( "Generated real random number is too short");
return -1;
memcpy( output, rnd_number, len );
return 0;
static void log_key(mbedtls_pk_context * key, int (f_writer)( mbedtls_pk_context *, unsigned char *, size_t), char* err_buf, size_t err_buf_length)
unsigned char buf[1024];
int err = f_writer(key, buf, sizeof(buf));
if (err != 0)
mbedtls_strerror(err, err_buf, err_buf_length);
LOG_ERR("Can not write -0x%04x - %s\n\n", (unsigned int) -err, err_buf);
return;
LOG_INF("\n%s",buf);
static inline void log_private_key(mbedtls_pk_context * key, char* err_buf, size_t err_buf_length)
log_key(key, mbedtls_pk_write_key_pem, err_buf, err_buf_length);
static inline void log_public_key(mbedtls_pk_context * key, char* err_buf, size_t err_buf_length)
log_key(key, mbedtls_pk_write_pubkey_pem, err_buf, err_buf_length);
static void log_keys(mbedtls_pk_context * key, char* err_buf, size_t err_buf_length)
log_private_key(key, err_buf, err_buf_length);
log_public_key(key, err_buf, err_buf_length);
static int generate_key(mbedtls_pk_context * key, char* err_buf, size_t err_buf_length)
int err;
LOG_INF("Generating key pairs, it takes ~3 sec.");
mbedtls_pk_init(key);
if ((err = mbedtls_pk_setup(key, mbedtls_pk_info_from_type( MBEDTLS_PK_ECKEY))) != 0)
LOG_ERR("Can't setup key context -0x%04x - %s\n\n", (unsigned int) -err, err_buf);
return err;
err = mbedtls_ecp_gen_key(MBEDTLS_ECP_DP_SECP256R1, /*ec_curve,*/
mbedtls_pk_ec(*key),
gen_true_random_number, NULL );
if (err != 0)
LOG_ERR("Can not generate key -0x%04x - %s\n\n", (unsigned int) -err, err_buf);
return err;
LOG_INF( "Key pair generated.");
return 0;
// https://tls.mbed.org/kb/how-to/generate-a-self-signed-certificate
// https://github.com/ARMmbed/mbedtls/blob/development/programs/pkey/gen_key.c
Check whether the generated key pair are right:
1. log_keys(&key)
2. Copy the content into private_key.pem, public_key.pem
3. Verify them with a sign and verify process
cat blablabla > bla.txt
openssl dgst -sha1 -sign private_key.pem bla.txt > signature.bin
openssl dgst -sha1 -verify public_key.pem -signature signature.bin bla.txt
void main(void)
char err_buf[512];
mbedtls_pk_context key;
if (generate_key(&key, err_buf, sizeof(err_buf)) != 0)
return;
log_keys(&key, err_buf, sizeof(err_buf));
mbedtls_pk_free(&key);
That's it.
The x509 certificate creation needs more setup and code but because it's not needed I don't post it.
Árpád
I try to achieve the same thing. Thanks for posting a step by step guide. I will try this out. I guess the workaround (part 1 above) is no longer needed with the current release (v1.5.1) of NRF Connect. Correct? What about part 4. Were there any changes in NRF Connect regarding generating the entropy?
Michael
