UARTE isn't working
Hi. I'm writing my own libraries for nRF52832 and I can't get UARTE to work.
Here is my code.
I'm using pins 6 and 8 as the UART example.
I wrote same code for UART (without DMA) and it works fine!
uart.c file
#include <string.h>
#include <stdbool.h>
#include "nrf52.h"
#include "uart.h"
static volatile uint8_t tx_buffer[128];
void uart_set_baudrate(uint32_t val)
    NRF_UARTE0->BAUDRATE = val;
void uart_configure(uint32_t parity, uint32_t hwfc)
    NRF_UARTE0->CONFIG = (parity << UART_CONFIG_PARITY_Pos) | (hwfc << UART_CONFIG_HWFC_Pos);
void uart_set_pins(uint32_t txpin, uint32_t rxpin)
    NRF_UARTE0->PSEL.RXD = rxpin;
    NRF_UARTE0->PSEL.TXD = txpin;
void uart_enable(void)
    NRF_UARTE0->ENABLE = UART_ENABLE_ENABLE_Enabled;
void uart_init(void)
    uart_set_baudrate(UART_BAUDRATE_BAUDRATE_Baud115200);
    uart_configure(UART_CONFIG_PARITY_Excluded, UART_CONFIG_HWFC_Disabled);
    uart_set_pins(6, 8);
    uart_enable();
void uart_write_string(uint8_t * str, int size)
    memcpy(tx_buffer, str, size);
    NRF_UARTE0->TXD.PTR = (uint32_t)((uint8_t *)tx_buffer);
    NRF_UARTE0->TXD.MAXCNT = size;
    NRF_UARTE0->TASKS_STARTTX = 1;
main.c
    clock_init();
    rtc_init();
    gpio_out_set(6);
    gpio_config_output(6);
    gpio_config_input(8, GPIO_PIN_CNF_PULL_Disabled);
    uart_init();
    uart_write_string("Hello world\r\n", 14);
    radio_init();
    __enable_irq();
    while (true)
I don't get anything on the terminal.
