Dear all,
I want to measure the current consumption of my application on a nRF52833 DK. On top of that I want to be able to power the device using the VDDH and set the VDD to one of the available values:
#define UICR_REGOUT0_VOUT_1V8 (0UL) /*!< 1.8 V */ #define UICR_REGOUT0_VOUT_2V1 (1UL) /*!< 2.1 V */ #define UICR_REGOUT0_VOUT_2V4 (2UL) /*!< 2.4 V */ #define UICR_REGOUT0_VOUT_2V7 (3UL) /*!< 2.7 V */ #define UICR_REGOUT0_VOUT_3V0 (4UL) /*!< 3.0 V */ #define UICR_REGOUT0_VOUT_3V3 (5UL) /*!< 3.3 V */ #define UICR_REGOUT0_VOUT_DEFAULT (7UL) /*!< Default voltage: 1.8 V */
What I have achieved so far is to measure current using an OTII device, by applying voltage on the LiPo connector and switching SW9 to LiPo and by switching the SW6 to nRF Only.
But I am not sure if this configuration uses the VDD or the VDDH. On my code in the sdk_config.h I have the following configuration:
// <e> POWER_ENABLED - nrf_drv_power - POWER peripheral driver - legacy layer //========================================================== #ifndef POWER_ENABLED #define POWER_ENABLED 1 #endif // <o> POWER_CONFIG_IRQ_PRIORITY - Interrupt priority // <i> Priorities 0,2 (nRF51) and 0,1,4,5 (nRF52) are reserved for SoftDevice // <0=> 0 (highest) // <1=> 1 // <2=> 2 // <3=> 3 // <4=> 4 // <5=> 5 // <6=> 6 // <7=> 7 #ifndef POWER_CONFIG_IRQ_PRIORITY #define POWER_CONFIG_IRQ_PRIORITY 6 #endif // <q> POWER_CONFIG_DEFAULT_DCDCEN - The default configuration of main DCDC regulator // <i> This settings means only that components for DCDC regulator are installed and it can be enabled. #ifndef POWER_CONFIG_DEFAULT_DCDCEN #define POWER_CONFIG_DEFAULT_DCDCEN 0 #endif // <q> POWER_CONFIG_DEFAULT_DCDCENHV - The default configuration of High Voltage DCDC regulator // <i> This settings means only that components for DCDC regulator are installed and it can be enabled. #ifndef POWER_CONFIG_DEFAULT_DCDCENHV #define POWER_CONFIG_DEFAULT_DCDCENHV 1 #endif // </e>
On top of that I have followed the suggestions on this question:
https://devzone.nordicsemi.com/f/nordic-q-a/28562/nrf52840-regulator-configuration/142110#142110
I created a uicr_config.h file that I included in my main.c that looks like this:
#ifndef _UICR_CONFIG_H #define _UICR_CONFIG_H /*lint ++flb "Enter library region" */ #include <stdint.h> #ifdef __cplusplus extern "C" { #endif const uint32_t REGOUT0 __attribute__((section(".uicr_regout0"))) = 5; #ifdef __cplusplus } #endif #endif //_UICR_CONFIG_H
and
<!DOCTYPE Linker_Placement_File> <Root name="Flash Section Placement"> <MemorySegment name="FLASH" start="$(FLASH_PH_START)" size="$(FLASH_PH_SIZE)"> <ProgramSection load="no" name=".reserved_flash" start="$(FLASH_PH_START)" size="$(FLASH_START)-$(FLASH_PH_START)" /> <ProgramSection alignment="0x100" load="Yes" name=".vectors" start="$(FLASH_START)" /> <ProgramSection alignment="4" load="Yes" name=".init" /> <ProgramSection alignment="4" load="Yes" name=".init_rodata" /> <ProgramSection alignment="4" load="Yes" name=".text" /> <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_soc_observers" inputsections="*(SORT(.sdh_soc_observers*))" address_symbol="__start_sdh_soc_observers" end_symbol="__stop_sdh_soc_observers" /> <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_ble_observers" inputsections="*(SORT(.sdh_ble_observers*))" address_symbol="__start_sdh_ble_observers" end_symbol="__stop_sdh_ble_observers" /> <ProgramSection alignment="4" keep="Yes" load="Yes" name=".pwr_mgmt_data" inputsections="*(SORT(.pwr_mgmt_data*))" address_symbol="__start_pwr_mgmt_data" end_symbol="__stop_pwr_mgmt_data" /> <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_state_observers" inputsections="*(SORT(.sdh_state_observers*))" address_symbol="__start_sdh_state_observers" end_symbol="__stop_sdh_state_observers" /> <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_stack_observers" inputsections="*(SORT(.sdh_stack_observers*))" address_symbol="__start_sdh_stack_observers" end_symbol="__stop_sdh_stack_observers" /> <ProgramSection alignment="4" keep="Yes" load="Yes" name=".sdh_req_observers" inputsections="*(SORT(.sdh_req_observers*))" address_symbol="__start_sdh_req_observers" end_symbol="__stop_sdh_req_observers" /> <ProgramSection alignment="4" keep="Yes" load="Yes" name=".nrf_queue" inputsections="*(.nrf_queue*)" address_symbol="__start_nrf_queue" end_symbol="__stop_nrf_queue" /> <ProgramSection alignment="4" keep="Yes" load="Yes" name=".nrf_balloc" inputsections="*(.nrf_balloc*)" address_symbol="__start_nrf_balloc" end_symbol="__stop_nrf_balloc" /> <ProgramSection alignment="4" keep="Yes" load="Yes" name=".cli_command" inputsections="*(.cli_command*)" address_symbol="__start_cli_command" end_symbol="__stop_cli_command" /> <ProgramSection alignment="4" keep="Yes" load="Yes" name=".crypto_data" inputsections="*(SORT(.crypto_data*))" address_symbol="__start_crypto_data" end_symbol="__stop_crypto_data" /> <ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_const_data" inputsections="*(SORT(.log_const_data*))" address_symbol="__start_log_const_data" end_symbol="__stop_log_const_data" /> <ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_backends" inputsections="*(SORT(.log_backends*))" address_symbol="__start_log_backends" end_symbol="__stop_log_backends" /> <ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections" address_symbol="__start_nrf_sections" /> <ProgramSection alignment="4" keep="Yes" load="Yes" name=".cli_sorted_cmd_ptrs" inputsections="*(.cli_sorted_cmd_ptrs*)" runin=".cli_sorted_cmd_ptrs_run"/> <ProgramSection alignment="4" keep="Yes" load="Yes" name=".fs_data" inputsections="*(.fs_data*)" runin=".fs_data_run"/> <ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_dynamic_data" inputsections="*(SORT(.log_dynamic_data*))" runin=".log_dynamic_data_run"/> <ProgramSection alignment="4" keep="Yes" load="Yes" name=".log_filter_data" inputsections="*(SORT(.log_filter_data*))" runin=".log_filter_data_run"/> <ProgramSection alignment="4" load="Yes" name=".dtors" /> <ProgramSection alignment="4" load="Yes" name=".ctors" /> <ProgramSection alignment="4" load="Yes" name=".rodata" /> <ProgramSection alignment="4" load="Yes" name=".ARM.exidx" address_symbol="__exidx_start" end_symbol="__exidx_end" /> <ProgramSection alignment="4" load="Yes" runin=".fast_run" name=".fast" /> <ProgramSection alignment="4" load="Yes" runin=".data_run" name=".data" /> <ProgramSection alignment="4" load="Yes" runin=".tdata_run" name=".tdata" /> </MemorySegment> <MemorySegment name="RAM" start="$(RAM_PH_START)" size="$(RAM_PH_SIZE)"> <ProgramSection load="no" name=".reserved_ram" start="$(RAM_PH_START)" size="$(RAM_START)-$(RAM_PH_START)" /> <ProgramSection alignment="0x100" load="No" name=".vectors_ram" start="$(RAM_START)" address_symbol="__app_ram_start__"/> <ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections_run" address_symbol="__start_nrf_sections_run" /> <ProgramSection alignment="4" keep="Yes" load="No" name=".cli_sorted_cmd_ptrs_run" address_symbol="__start_cli_sorted_cmd_ptrs" end_symbol="__stop_cli_sorted_cmd_ptrs" /> <ProgramSection alignment="4" keep="Yes" load="No" name=".fs_data_run" address_symbol="__start_fs_data" end_symbol="__stop_fs_data" /> <ProgramSection alignment="4" keep="Yes" load="No" name=".log_dynamic_data_run" address_symbol="__start_log_dynamic_data" end_symbol="__stop_log_dynamic_data" /> <ProgramSection alignment="4" keep="Yes" load="No" name=".log_filter_data_run" address_symbol="__start_log_filter_data" end_symbol="__stop_log_filter_data" /> <ProgramSection alignment="4" keep="Yes" load="No" name=".nrf_sections_run_end" address_symbol="__end_nrf_sections_run" /> <ProgramSection alignment="4" load="No" name=".fast_run" /> <ProgramSection alignment="4" load="No" name=".data_run" /> <ProgramSection alignment="4" load="No" name=".tdata_run" /> <ProgramSection alignment="4" load="No" name=".bss" /> <ProgramSection alignment="4" load="No" name=".tbss" /> <ProgramSection alignment="4" load="No" name=".non_init" /> <ProgramSection alignment="4" size="__HEAPSIZE__" load="No" name=".heap" /> <ProgramSection alignment="8" size="__STACKSIZE__" load="No" place_from_segment_end="Yes" name=".stack" address_symbol="__StackLimit" end_symbol="__StackTop"/> <ProgramSection alignment="8" size="__STACKSIZE_PROCESS__" load="No" name=".stack_process" /> </MemorySegment> <MemorySegment name="UICR" start="$(UICR_START)" size="$(UICR_SIZE)"> <ProgramSection alignment="4" keep="Yes" load="Yes" name=".uicr_regout0" start="0x10001304" size="4"/> </MemorySegment> </Root>
What I did was to modify the following lines in my .emProject:
linker_section_placements_segments="FLASH RX 0x0 0x80000;RAM RWX 0x20000000 0x20000;UICR RX 0x10001000 0x304"
which causes this error: C:/Program Files/SEGGER/SEGGER Embedded Studio for ARM 4.52c/gcc/arm-none-eabi/bin/ld: error: .uicr_regout0 is too large to fit in UICR memory segment.
If I skip the step that does not allow my project to build, and I measure the voltage on the vDD_nRF I get 1.8V, which is the default value.
My setup is the following:
nRF5SDK 16.0.0
nRF52833DK
Apply 3.3V on the LiPO connector and SW9 and SW6 are configured as described above.
So the main question is how do I need to configure my setup in order to be able to set and measure the desired VDD?
