twi sensor i am not getting the data
hi,
i am using nrf52832 devkit and max30208 temp. sensor. i am not getting updated data. iprefer this link for i2c address.(https://os.mbed.com/users/cyberjoey/code/OT07_I2C_GUI_Firmware//file/2e7483c7281b/main.cpp/)
source code
/** @file
* @defgroup tw_sensor_example main.c
* @ingroup nrf_twi_example
* @brief TWI Sensor Example main file.
* This file contains the source code for a sample application using TWI.
#include <stdio.h>
#include "boards.h"
#include "app_error.h"
#include "nrf_drv_twi.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
/* TWI instance ID. */
#define TWI_INSTANCE_ID 0
/* Common addresses definition for temperature sensor. */
#define max30208_slave_add 0x50U // (0x50U >> 1)
#define max30208_config 0x01U
#define max30208_read_data 0x08U
#define max30208_temp_setup 0x14U
#define max30208_temp_setup_value 0xC1U
#define LM75B_REG_TEMP 0x00U
#define LM75B_REG_CONF 0x01U
#define LM75B_REG_THYST 0x02U
#define LM75B_REG_TOS 0x03U
#define OT07_FIFO_DATA 0x08U // read temp. data
#define OT07_ADC_SETUP 0x14 // OT07 Temp Seneor Setup (ADC_RES[7:6]) & Convert Temperature [0]
/* Mode for LM75B. */
#define NORMAL_MODE 0U
/* Indicates if operation on TWI has ended. */
static volatile bool m_xfer_done = false;
/* TWI instance. */
static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
double Temp_sample;
static void temp_tx_setup(void)
ret_code_t err_code;
uint8_t reg[2] = {max30208_temp_setup, max30208_temp_setup_value};
err_code = nrf_drv_twi_tx(&m_twi, max30208_slave_add, reg, sizeof(reg), false);
while (m_xfer_done == false);
static void temp_rx_setup(void)
char data[2];
uint16_t count;
uint8_t reg[1] = {max30208_read_data};
err_code = nrf_drv_twi_tx(&m_twi, max30208_slave_add, reg, 2, false);
err_code = nrf_drv_twi_rx(&m_twi, max30208_read_data, data, 2);
NRF_LOG_INFO("Temperature:data %d ", count);
* @brief Function for setting active mode on MMA7660 accelerometer.
void max30208_setmode(void)
/* Writing to LM75B_REG_CONF "0" set temperature sensor in NORMAL mode. */
uint8_t reg[2] = {max30208_config, NORMAL_MODE};
/* Writing to pointer byte. */
/* reg[0] = OT07_ADC_SETUP;
err_code = nrf_drv_twi_tx(&m_twi, LM75B_ADDR, reg, 1, false);
while (m_xfer_done == false);*/
/* reg[0] = OT07_FIFO_DATA;
* @brief Function for handling data from temperature sensor.
* @param[in] temp Temperature in Celsius degrees read from sensor.
__STATIC_INLINE void data_handler(double temp)
//NRF_LOG_INFO("Temperature: %lf, int %d Celsius degrees.",temp, (int) temp);
* @brief TWI events handler.
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
switch (p_event->type)
case NRF_DRV_TWI_EVT_DONE:
if (p_event->xfer_desc.type == NRF_DRV_TWI_XFER_RX)
data_handler(Temp_sample);
NRF_LOG_INFO("data sent event");
m_xfer_done = true;
* @brief UART initialization.
void twi_init (void)
const nrf_drv_twi_config_t twi_lm75b_config = {
.scl = ARDUINO_SCL_PIN,
.sda = ARDUINO_SDA_PIN,
.frequency = NRF_DRV_TWI_FREQ_400K,
.interrupt_priority = APP_IRQ_PRIORITY_HIGH,
.clear_bus_init = false
err_code = nrf_drv_twi_init(&m_twi, &twi_lm75b_config, twi_handler, NULL);
nrf_drv_twi_enable(&m_twi);
* @brief Function for reading data from temperature sensor.
static void read_sensor_data()
temp_tx_setup();
nrf_delay_ms(500);
char data[2];
uint16_t count;
//calculate temperture from data
count = (uint16_t)(data[0]*256 + data[1]);
if (count >= 32768)
{count = 65536 - count;}
Temp_sample = (double)(count * 0.005);
NRF_LOG_INFO("Temperature data: %d , %X ", ,Temp_sample);
NRF_LOG_INFO("\r\nTWI sensor example started.");
NRF_LOG_FLUSH();
twi_init();
max30208_setmode();
while (true)
nrf_delay_ms(500);
do
__WFE();
}while (m_xfer_done == false);
read_sensor_data();
NRF_LOG_FLUSH();
