I2S loopback example missing in installation folder
I setup NRF SDK using nrfconnectsetup341ia32 executable.
I2S example file should be located at <InstallFolder>\examples\peripheral\i2s according to https://infocenter.nordicsemi.com/index.jsp?topic=%2Fcom.nordic.infocenter.sdk5.v11.0.0%2Fi2s_example_loopback.html.
But no such folder is available.
Can you please help?
  • Add CONFIG_NRFX_I2S=y to prj.conf file in order to include the driver's source file in the build system.
    Add #include <nrfx_i2s.h> to your main.c file.
  • Thank you for this information. I am able to build and run the application.
    When I ran the application i got "E: >>> ZEPHYR FATAL ERROR 1: Unhandled interrupt on CPU 0" error. "nrfx_i2s_init" is successful. I used 26, 27, 28, 29, 30 for sck_pin, lrck_pin, mck_pin, sdout_pin and sdin_pin respectively.
    When "nrfx_i2s_start" is called, app crashed with above mentioned error.
    When debugged further, crash occurred inside "nrf_i2s_task_trigger" function.
    Can you please let me know how to fix this error?
    Can you please let me know what pins should I be using for IN, OUT and clocks of I2S?
  • Here is the code used
    #include <zephyr.h>
    #include <ztest.h>
    #include <device.h>
    #include <drivers/i2s.h>
    #include <nrf.h>
    #include <nrfx.h>
    #include "i2s_api_test.h"
    static void data_handler(nrfx_i2s_buffers_t const * p_released,
    uint32_t status)
    if(p_released != NULL) {
    if(p_released->p_rx_buffer != NULL) {
    printf("RX buffer received\n");
    } else if(p_released->p_tx_buffer) {
    printf("TX buffer received\n");
    } else {
    printf("RX/TX buffer not received\n");
    } else {
    printf("Received buffers are NULL\n");
    #define PAUSE_TIME 500
    #define I2S_BUFFER_SIZE 1000
    static uint32_t m_buffer_rx[I2S_BUFFER_SIZE];
    static uint32_t m_buffer_tx[I2S_BUFFER_SIZE];
    void test_main(void)
    nrfx_i2s_config_t i2s_cfg = NRFX_I2S_DEFAULT_CONFIG(0, 1, 17, 20, 22);
    nrfx_i2s_buffers_t nrx_buf;
    nrx_buf.p_rx_buffer = m_buffer_rx;
    nrx_buf.p_tx_buffer = m_buffer_tx;
    err_code = nrfx_i2s_init(&i2s_cfg, data_handler);
    printf("nrfx_i2s_init return code is %u\n", err_code);
    for(index = 0; index < 10; index++)
    err_code = nrfx_i2s_start(&nrx_buf, I2S_BUFFER_SIZE, 0);
    printf("nrfx_i2s_start return code is %u\n", err_code);
    k_sleep(K_MSEC(100));
    nrfx_i2s_stop();
    printf("After nrfx_i2s_stop \n");
  • Can you please check the above code and let me know if I am doing anything wrong?
