Compile error DFU OTA 52832 - SUPPRESS_INLINE_IMPLEMENTATION
I have DFU OTA application running on 52840 platform on a custom board. SDK v15.3.0. I use SoftDevoce S140 v6.1.1.
Then I need to port it to 52832 platform - SoftDevice S132 v6.1.1. Same, SDK 15.3.0.
I changed the crypto to use micro_ecc, and disabled UART1 and also UARTE1, and re-ordered the path and include.
However, I kept getting this compilation error:
"C:\NRF52832\sDevice\V6_11\s132\include\nrf_nvic.h", line 290: Error:  #40: expected an identifier
    int pm = __get_PRIMASK();
"C:\NRF52832\sDevice\V6_11\s132\include\nrf_nvic.h", line 292: Error:  #117: non-void function "__sd_nvic_irq_disable"  should return a value
    return pm;
I foudn that by using SUPPRESS_INLINE_IMPLEMENTATION directive, I can get rid of that error.
However, another error appears:
"C:\NRF52832\SDK\V15_3_0\MODULES\nrfx\soc/nrfx_coredep.h", line 96: Error:  #114: function "nrfx_coredep_delay_us"  was referenced but not defined
  __STATIC_INLINE void nrfx_coredep_delay_us(uint32_t time_us);
"C:\NRF52832\SDK\V15_3_0\MODULES\nrfx\hal\nrf_gpio.h", line 233: Error:  #114: function "nrf_gpio_cfg_sense_input"  was referenced but not defined
  __STATIC_INLINE void nrf_gpio_cfg_sense_input(uint32_t             pin_number,
"C:\NRF52832\SDK\V15_3_0\MODULES\nrfx\hal\nrf_gpio.h", line 308: Error:  #114: function "nrf_gpio_pin_read"  was referenced but not defined
  __STATIC_INLINE uint32_t nrf_gpio_pin_read(uint32_t pin_number);
"C:\NRF52832\SDK\V15_3_0\MODULES\nrfx\hal\nrf_power.h", line 507: Error:  #114: function "nrf_power_resetreas_get"  was referenced but not defined
  __STATIC_INLINE uint32_t nrf_power_resetreas_get(void);
"C:\NRF52832\SDK\V15_3_0\MODULES\nrfx\hal\nrf_power.h", line 517: Error:  #114: function "nrf_power_resetreas_clear"  was referenced but not defined
  __STATIC_INLINE void nrf_power_resetreas_clear(uint32_t mask);
"C:\NRF52832\SDK\V15_3_0\MODULES\nrfx\hal\nrf_power.h", line 603: Error:  #114: function "nrf_power_gpregret_set"  was referenced but not defined
  __STATIC_INLINE void nrf_power_gpregret_set(uint8_t val);
"C:\NRF52832\SDK\V15_3_0\MODULES\nrfx\hal\nrf_power.h", line 610: Error:  #114: function "nrf_power_gpregret_get"  was referenced but not defined
  __STATIC_INLINE uint8_t nrf_power_gpregret_get(void);
"C:\NRF52832\SDK\V15_3_0\MODULES\nrfx\hal\nrf_power.h", line 620: Error:  #114: function "nrf_power_gpregret2_set"  was referenced but not defined
  __STATIC_INLINE void nrf_power_gpregret2_set(uint8_t val);
"C:\NRF52832\SDK\V15_3_0\MODULES\nrfx\hal\nrf_power.h", line 629: Error:  #114: function "nrf_power_gpregret2_get"  was referenced but not defined
  __STATIC_INLINE uint8_t nrf_power_gpregret2_get(void);
  • Hi Edvin, after I rearrange the order of compilation, it works now. Thanks for your help.
    But now I encounter OTA DFU failure. Do you want me to open a new case? Let me know.
    This is the error from the log of nRF Connect for Desktop (the last chunk):
    2020-07-17T00:59:37.254Z DEBUG GATTC_EVT_WRITE_RSP time:2020-07-17T00:59:37.256Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 handle:15 writeOp:1 offset:0 len:0
    2020-07-17T00:59:37.254Z INFO Attribute value changed, handle: 0x0F, value (0x): 01-01-8D-00-00-00
    2020-07-17T00:59:37.287Z DEBUG   667/ 0 <-  [02 39 00 00 00 00 00 00 00 0f 00 01 03 00 60 01 01 ] type:     VENDOR_SPECIFIC reliable:yes seq#:5 ack#:0 payload_length:11 data_integrity:1 header_checksum:1c err_code:0x0
    2020-07-17T00:59:37.287Z DEBUG      670 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:6 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:37.288Z DEBUG GATTC_EVT_HVX time:2020-07-17T00:59:37.289Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 handle:15 type:1 len:3
    2020-07-17T00:59:37.288Z INFO Attribute value changed, handle: 0x0F, value (0x): 60-01-01
    2020-07-17T00:59:37.288Z DEBUG      671 ->  [00 9c 00 00 01 02 00 0d 00 00 00 8d 00 01 12 8a 01 0a 44 08 01 12 40 08 01 10 34 1a 02 b7 01 20 00 28 00 30 00 38 88 a0 15 42 24 08 03 12 20 10 2d 02 d1 33 f7 3a ee 5e e8 9e 7a 61 d7 39 ab b8 e3 0f 41 e2 7f 74 9f 72 6c 94 14 3d 0f ee 05 48 00 52 04 08 01 12 00 10 00 1a 40 2b 63 90 d1 33 86 f7 29 e1 1f 9c cf 10 ec da 6f 13 79 b7 fd a6 16 78 da 73 cf e6 af fb b1 ef ee e2 5d 4d af d0 7e d6 64 5c 9e 10 87 82 84 1a 5b 7f ea e4 09 2f 44 b6 88 f1 8e 15 81 c0 cd 2c 9a ] type:     VENDOR_SPECIFIC reliable:yes seq#:0 ack#:6 payload_length:9b data_integrity:1 header_checksum:49 err_code:0x0
    2020-07-17T00:59:37.324Z DEBUG   668/ 0 <-  [N/A] type:                 ACK reliable: no seq#:0 ack#:1 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:37.324Z DEBUG   669/ 0 <-  [01 9c 00 00 00 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:6 ack#:1 payload_length:6 data_integrity:1 header_checksum:c4 err_code:0x0
    2020-07-17T00:59:37.324Z DEBUG      672 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:7 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:37.357Z DEBUG   670/ 0 <-  [02 3c 00 00 00 00 00 00 00 01 ] type:     VENDOR_SPECIFIC reliable:yes seq#:7 ack#:1 payload_length:a data_integrity:1 header_checksum:83 err_code:0x0
    2020-07-17T00:59:37.357Z DEBUG      673 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:0 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:37.357Z DEBUG  time:2020-07-17T00:59:37.359Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 count:1
    2020-07-17T00:59:37.358Z DEBUG      674 ->  [00 9c 00 00 01 01 00 0f 00 00 00 01 00 01 03 ] type:     VENDOR_SPECIFIC reliable:yes seq#:1 ack#:0 payload_length:f data_integrity:1 header_checksum:41 err_code:0x0
    2020-07-17T00:59:37.391Z DEBUG   671/ 0 <-  [N/A] type:                 ACK reliable: no seq#:0 ack#:2 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:37.391Z DEBUG   672/ 0 <-  [01 9c 00 00 00 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:0 ack#:2 payload_length:6 data_integrity:1 header_checksum:c2 err_code:0x0
    2020-07-17T00:59:37.391Z DEBUG      675 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:1 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:37.424Z DEBUG   673/ 0 <-  [02 38 00 00 00 00 00 00 00 0f 00 01 00 00 00 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:1 ack#:2 payload_length:10 data_integrity:1 header_checksum:20 err_code:0x0
    2020-07-17T00:59:37.424Z DEBUG      676 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:2 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:37.424Z DEBUG GATTC_EVT_WRITE_RSP time:2020-07-17T00:59:37.426Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 handle:15 writeOp:1 offset:0 len:0
    2020-07-17T00:59:37.424Z INFO Attribute value changed, handle: 0x0F, value (0x): 03
    2020-07-17T00:59:37.455Z DEBUG   674/ 0 <-  [02 39 00 00 00 00 00 00 00 0f 00 01 0b 00 60 03 01 8d 00 00 00 0a cf ef 07 ] type:     VENDOR_SPECIFIC reliable:yes seq#:2 ack#:2 payload_length:19 data_integrity:1 header_checksum:8f err_code:0x0
    2020-07-17T00:59:37.456Z DEBUG      677 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:3 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:37.456Z DEBUG GATTC_EVT_HVX time:2020-07-17T00:59:37.458Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 handle:15 type:1 len:11
    2020-07-17T00:59:37.456Z INFO Attribute value changed, handle: 0x0F, value (0x): 60-03-01-8D-00-00-00-0A-CF-EF-07
    2020-07-17T00:59:37.461Z DEBUG      678 ->  [00 9c 00 00 01 01 00 0f 00 00 00 01 00 01 04 ] type:     VENDOR_SPECIFIC reliable:yes seq#:2 ack#:3 payload_length:f data_integrity:1 header_checksum:28 err_code:0x0
    2020-07-17T00:59:37.495Z DEBUG   675/ 0 <-  [N/A] type:                 ACK reliable: no seq#:0 ack#:3 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:37.497Z DEBUG   676/ 0 <-  [01 9c 00 00 00 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:3 ack#:3 payload_length:6 data_integrity:1 header_checksum:b7 err_code:0x0
    2020-07-17T00:59:37.497Z DEBUG      679 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:4 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:37.525Z DEBUG   677/ 0 <-  [02 38 00 00 00 00 00 00 00 0f 00 01 00 00 00 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:4 ack#:3 payload_length:10 data_integrity:1 header_checksum:15 err_code:0x0
    2020-07-17T00:59:37.526Z DEBUG      680 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:5 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:37.526Z DEBUG GATTC_EVT_WRITE_RSP time:2020-07-17T00:59:37.527Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 handle:15 writeOp:1 offset:0 len:0
    2020-07-17T00:59:37.526Z INFO Attribute value changed, handle: 0x0F, value (0x): 04
    2020-07-17T00:59:37.648Z DEBUG   678/ 0 <-  [02 39 00 00 00 00 00 00 00 0f 00 01 03 00 60 04 05 ] type:     VENDOR_SPECIFIC reliable:yes seq#:5 ack#:3 payload_length:11 data_integrity:1 header_checksum:4 err_code:0x0
    2020-07-17T00:59:37.648Z DEBUG      681 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:6 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:37.648Z DEBUG GATTC_EVT_HVX time:2020-07-17T00:59:37.650Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 handle:15 type:1 len:3
    2020-07-17T00:59:37.649Z INFO Attribute value changed, handle: 0x0F, value (0x): 60-04-05
    2020-07-17T00:59:37.651Z DEBUG      682 ->  [00 9c 00 00 01 01 00 0f 00 00 00 06 00 01 01 01 8d 00 00 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:3 ack#:6 payload_length:14 data_integrity:1 header_checksum:be err_code:0x0
    2020-07-17T00:59:37.685Z DEBUG   679/ 0 <-  [N/A] type:                 ACK reliable: no seq#:0 ack#:4 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:37.685Z DEBUG   680/ 0 <-  [01 9c 00 00 00 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:6 ack#:4 payload_length:6 data_integrity:1 header_checksum:ac err_code:0x0
    2020-07-17T00:59:37.685Z DEBUG      683 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:7 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:37.718Z DEBUG   681/ 0 <-  [02 38 00 00 00 00 00 00 00 0f 00 01 00 00 00 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:7 ack#:4 payload_length:10 data_integrity:1 header_checksum:a err_code:0x0
    2020-07-17T00:59:37.718Z DEBUG      684 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:0 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:37.718Z DEBUG GATTC_EVT_WRITE_RSP time:2020-07-17T00:59:37.720Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 handle:15 writeOp:1 offset:0 len:0
    2020-07-17T00:59:37.718Z INFO Attribute value changed, handle: 0x0F, value (0x): 01-01-8D-00-00-00
    2020-07-17T00:59:37.751Z DEBUG   682/ 0 <-  [02 39 00 00 00 00 00 00 00 0f 00 01 03 00 60 01 01 ] type:     VENDOR_SPECIFIC reliable:yes seq#:0 ack#:4 payload_length:11 data_integrity:1 header_checksum:1 err_code:0x0
    2020-07-17T00:59:37.751Z DEBUG      685 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:1 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:37.751Z DEBUG GATTC_EVT_HVX time:2020-07-17T00:59:37.753Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 handle:15 type:1 len:3
    2020-07-17T00:59:37.751Z INFO Attribute value changed, handle: 0x0F, value (0x): 60-01-01
    2020-07-17T00:59:37.752Z DEBUG      686 ->  [00 9c 00 00 01 02 00 0d 00 00 00 8d 00 01 12 8a 01 0a 44 08 01 12 40 08 01 10 34 1a 02 b7 01 20 00 28 00 30 00 38 88 a0 15 42 24 08 03 12 20 10 2d 02 d1 33 f7 3a ee 5e e8 9e 7a 61 d7 39 ab b8 e3 0f 41 e2 7f 74 9f 72 6c 94 14 3d 0f ee 05 48 00 52 04 08 01 12 00 10 00 1a 40 2b 63 90 d1 33 86 f7 29 e1 1f 9c cf 10 ec da 6f 13 79 b7 fd a6 16 78 da 73 cf e6 af fb b1 ef ee e2 5d 4d af d0 7e d6 64 5c 9e 10 87 82 84 1a 5b 7f ea e4 09 2f 44 b6 88 f1 8e 15 81 c0 cd 2c 9a ] type:     VENDOR_SPECIFIC reliable:yes seq#:4 ack#:1 payload_length:9b data_integrity:1 header_checksum:6d err_code:0x0
    2020-07-17T00:59:37.787Z DEBUG   683/ 0 <-  [N/A] type:                 ACK reliable: no seq#:0 ack#:5 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:37.787Z DEBUG   684/ 0 <-  [01 9c 00 00 00 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:1 ack#:5 payload_length:6 data_integrity:1 header_checksum:a9 err_code:0x0
    2020-07-17T00:59:37.787Z DEBUG      687 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:2 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:37.819Z DEBUG   685/ 0 <-  [02 3c 00 00 00 00 00 00 00 01 ] type:     VENDOR_SPECIFIC reliable:yes seq#:2 ack#:5 payload_length:a data_integrity:1 header_checksum:68 err_code:0x0
    2020-07-17T00:59:37.819Z DEBUG      688 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:3 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:37.820Z DEBUG  time:2020-07-17T00:59:37.821Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 count:1
    2020-07-17T00:59:37.820Z DEBUG      689 ->  [00 9c 00 00 01 01 00 0f 00 00 00 01 00 01 03 ] type:     VENDOR_SPECIFIC reliable:yes seq#:5 ack#:3 payload_length:f data_integrity:1 header_checksum:25 err_code:0x0
    2020-07-17T00:59:37.853Z DEBUG   686/ 0 <-  [N/A] type:                 ACK reliable: no seq#:0 ack#:6 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:37.853Z DEBUG   687/ 0 <-  [01 9c 00 00 00 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:3 ack#:6 payload_length:6 data_integrity:1 header_checksum:9f err_code:0x0
    2020-07-17T00:59:37.853Z DEBUG      690 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:4 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:37.885Z DEBUG   688/ 0 <-  [02 38 00 00 00 00 00 00 00 0f 00 01 00 00 00 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:4 ack#:6 payload_length:10 data_integrity:1 header_checksum:fd err_code:0x0
    2020-07-17T00:59:37.885Z DEBUG      691 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:5 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:37.886Z DEBUG GATTC_EVT_WRITE_RSP time:2020-07-17T00:59:37.887Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 handle:15 writeOp:1 offset:0 len:0
    2020-07-17T00:59:37.886Z INFO Attribute value changed, handle: 0x0F, value (0x): 03
    2020-07-17T00:59:37.917Z DEBUG   689/ 0 <-  [02 39 00 00 00 00 00 00 00 0f 00 01 0b 00 60 03 01 8d 00 00 00 0a cf ef 07 ] type:     VENDOR_SPECIFIC reliable:yes seq#:5 ack#:6 payload_length:19 data_integrity:1 header_checksum:6c err_code:0x0
    2020-07-17T00:59:37.917Z DEBUG      692 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:6 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:37.917Z DEBUG GATTC_EVT_HVX time:2020-07-17T00:59:37.919Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 handle:15 type:1 len:11
    2020-07-17T00:59:37.918Z INFO Attribute value changed, handle: 0x0F, value (0x): 60-03-01-8D-00-00-00-0A-CF-EF-07
    2020-07-17T00:59:37.922Z DEBUG      693 ->  [00 9c 00 00 01 01 00 0f 00 00 00 01 00 01 04 ] type:     VENDOR_SPECIFIC reliable:yes seq#:6 ack#:6 payload_length:f data_integrity:1 header_checksum:c err_code:0x0
    2020-07-17T00:59:37.956Z DEBUG   690/ 0 <-  [N/A] type:                 ACK reliable: no seq#:0 ack#:7 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:37.957Z DEBUG   691/ 0 <-  [01 9c 00 00 00 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:6 ack#:7 payload_length:6 data_integrity:1 header_checksum:94 err_code:0x0
    2020-07-17T00:59:37.957Z DEBUG      694 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:7 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:37.988Z DEBUG   692/ 0 <-  [02 38 00 00 00 00 00 00 00 0f 00 01 00 00 00 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:7 ack#:7 payload_length:10 data_integrity:1 header_checksum:f2 err_code:0x0
    2020-07-17T00:59:37.988Z DEBUG      695 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:0 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:37.988Z DEBUG GATTC_EVT_WRITE_RSP time:2020-07-17T00:59:37.990Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 handle:15 writeOp:1 offset:0 len:0
    2020-07-17T00:59:37.988Z INFO Attribute value changed, handle: 0x0F, value (0x): 04
    2020-07-17T00:59:38.113Z DEBUG   693/ 0 <-  [02 39 00 00 00 00 00 00 00 0f 00 01 03 00 60 04 05 ] type:     VENDOR_SPECIFIC reliable:yes seq#:0 ack#:7 payload_length:11 data_integrity:1 header_checksum:e9 err_code:0x0
    2020-07-17T00:59:38.113Z DEBUG      696 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:1 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:38.114Z DEBUG GATTC_EVT_HVX time:2020-07-17T00:59:38.115Z connHandle:0 gattStatus:0 gattStatusName:success errorHandle:0 handle:15 type:1 len:3
    2020-07-17T00:59:38.114Z INFO Attribute value changed, handle: 0x0F, value (0x): 60-04-05
    2020-07-17T00:59:38.118Z DEBUG Destroying DFU transport.
    2020-07-17T00:59:38.118Z ERROR DFU failed with error: When writing 'EXECUTE' command to Control Point Characteristic of DFU Target: Operation code 4 (EXECUTE) failed on DFU Target. Result code 5 (INVALID_OBJECT).
    2020-07-17T00:59:38.136Z DEBUG      697 ->  [00 76 00 00 13 ] type:     VENDOR_SPECIFIC reliable:yes seq#:7 ack#:1 payload_length:5 data_integrity:1 header_checksum:d3 err_code:0x0
    2020-07-17T00:59:38.172Z DEBUG   694/ 0 <-  [N/A] type:                 ACK reliable: no seq#:0 ack#:0 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:38.172Z DEBUG   695/ 0 <-  [01 76 00 00 00 00 ] type:     VENDOR_SPECIFIC reliable:yes seq#:1 ack#:0 payload_length:6 data_integrity:1 header_checksum:d1 err_code:0x0
    2020-07-17T00:59:38.172Z DEBUG      698 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:2 payload_length:0 data_integrity:0 err_code:0x0
    2020-07-17T00:59:38.204Z DEBUG GAP_EVT_DISCONNECTED time:2020-07-17T00:59:38.189Z connHandle:0 reason:22 reasonName:localHostTerminatedConnection
    2020-07-17T00:59:38.204Z DEBUG   696/ 0 <-  [02 11 00 00 00 16 ] type:     VENDOR_SPECIFIC reliable:yes seq#:2 ack#:0 payload_length:6 data_integrity:1 header_checksum:d0 err_code:0x0
    2020-07-17T00:59:38.204Z DEBUG      699 ->  [N/A] type:                 ACK reliable: no seq#:0 ack#:3 payload_length:0 data_integrity:0 err_code:0x0
  • I leave for vacation today, so yes. Please create a new ticket. It is always nice to have separate tickets with reflecting titles.
    Edvin
