BLE_App_Uart + ADC + PWM
Hi everyone.
I know this is gonna be a long story, thank you for your patience...
I have successfully utilized a few examples in the SDK15.3 directory on my PCA10056 including the PWM driver, BLE_APP_UART and SAADC.
Also I could merge the PWM driver example and the BLE_APP_Uart.
now that I have tried to add the SAADC example to my code, everything stops working, e.g. all the LEDs that are controlled by the buttons and the PWM driver and the UART output on my terminal... only a blank line is added on each loop. (neither log or printf work).
the code is built and flashed on the core successfully without any errors.
when I try to debug my code using Keil5 it shows that the program stops somewhere like "NRF_BREAKPOINT_COND", I am not aware what it is for. Here it is:
The code is quite large in the main.c file but as its built without any error I only add main function here:
    bool erase_bonds;
uint32_t err_code;
    // Initialize.
    uart_init();
    log_init();
    timers_init();
    power_management_init();
    ble_stack_init();
    gap_params_init();
    gatt_init();
    services_init();
    advertising_init();
    conn_params_init();
			//mig//
			printf("\r\n  .UART + PWM Periph \r\n");
//	    uint32_t err_code = NRF_LOG_INIT(NULL);
    ret_code_t ret_code = nrf_pwr_mgmt_init();
    APP_ERROR_CHECK(ret_code);
    saadc_init();
    saadc_sampling_event_init();
    NRF_LOG_INFO("SAADC HAL simple example started.");
	   //init app_button module, 50ms detection delay (button debouncing)
    err_code = app_button_init((app_button_cfg_t *)app_buttons,
                                   NUM_OF_BUTTONS,
                                   APP_TIMER_TICKS(50));//, APP_TIMER_PRESCALER));
    err_code = app_button_enable();
    // Start execution.
    advertising_start();
		    pwm_init();
    pwm_update_duty_cycle(DS);
    //demo2();
    // Enter main loop.
    for (;;)
				nrf_delay_ms(300);
			  printf("\r\nLoop.\r\n");
	  		NRF_LOG_FLUSH();
        nrf_pwr_mgmt_run();
  • As you may see, its s140 v6.1.1
    I assume this might be a stable version.
  • thanks for your response..
    yeah I found it somewhere in the forum so I changed it to use the timer_instance(1) although I didn't disable timer_instance(0) in the sdk_config.h because  in that thread, the engineer said that only changing the main.c would be sufficient...
    Is it true?
  • I've asked the SooftDevice team what assert that is, waiting for a reply.
    What function call is on line 1074 og main.c?
  • Thank you Haakonsh,
    I have posted the main.c in my previous replies, here is the code around line 1074, its actually an error process call function and before that, we have conn_param_init()
        conn_params_init();
    			//mig//
        APP_ERROR_CHECK(err_code);   --->1074
    And something more, I have checked the link You sent about hardware restrictions when utilizing softdevice, it says even "NVIC"  module is not available! that may be the root of my problem, because I didnt change anything about it when adding the "SAADC" example to the BLE example. seems like there are many issues for joining non-BLE examples to a BLE example...
    But what function assigned the error code that was sent to APP_ERROR_CHECK()?
    That won't be a problem as long as the SAADC driver is configured with an interrupt priority of 6 or 7 (default is 6 I think). So if you've just merged the SAADC example, with the same sdk_config.h settings then you're fine.
