nRF hangs when sending second UDP package using thread
Hi all,
Using the thread CLI example (on a PCA10056 board) as a starting point I would like nodes to connect automatically to a thread mesh when booting. I then want to use this mesh to exchange UDP packets.
The joining of the thread network works fine, and opening and sending a UDP package works fine the first time too.
However, when I then try to send a second package over the still opened UDP port the code hangs, it never returns from the otUdpSend method.
I can't seem to find what I'm still missing, so any help would be very welcome.
int main(int argc, char *argv[])
    log_init();
    scheduler_init();
    timer_init();
    leds_init();
    otError error;
    long counter = 0;
    uint32_t err_code = bsp_init(BSP_INIT_LEDS, NULL);
    while (true)
        // connect to thread mesh
        thread_instance_init();
        otLinkSetPanId(thread_ot_instance_get(), 5);
        otIp6SetEnabled(thread_ot_instance_get(), true);
        otThreadSetEnabled(thread_ot_instance_get(), true);
        const char buf[100] = "test123\0";
        otMessageInfo messageInfo;
        otUdpSocket mySocket;
        memset(&messageInfo, 0, sizeof(messageInfo));
        otIp6AddressFromString("ff03::1", &messageInfo.mPeerAddr);
        messageInfo.mPeerPort = 1994;
        error = otUdpOpen(thread_ot_instance_get(), &mySocket, HandleUdpReceive, NULL);
        otMessage *test_Message = otUdpNewMessage(thread_ot_instance_get(), NULL);
        otMessageAppend(test_Message, buf, (uint16_t)strlen(buf));
        NRF_LOG_INFO("after socket open");
        while (!thread_soft_reset_was_requested())
            thread_process();
            app_sched_execute();
                //thread_sleep();
            otError errorUdpSend = otUdpSend(&mySocket, test_Message, &messageInfo);
            NRF_LOG_INFO(otThreadErrorToString(errorUdpSend));
        NRF_LOG_INFO("SOFT RESET");
        thread_instance_finalize();
  • I managed to fix this issue, I've just called otCliConsoleInputLine() function after initialization phase within main() function of the receiver node :
    /*Initialization*/
    log_init();
    scheduler_init();
    timer_init();
    leds_init();
    /*udp open*/
    char cli_cmd[] = "udp open\r\n";
    otCliConsoleInputLine(cli_cmd, strlen(cli_cmd));
    /*udp bind :: 1994*/
    char cli_cmd_2[] = "udp bind :: 1994\r\n";
    otCliConsoleInputLine(cli_cmd_2, strlen(cli_cmd_2));
    It works perfectly.
    Kind Regards,
    Houssam
