Connecting the nRF9160DK to the nRF52833 over Bluetooth
I would like to set up a couple of boards communicating over Bluetooth; I was hoping someone could provide some pointers.
I would like to connect the nRF9160DK to the nRF52833DK.
I have programmed the nRF52 on the nRF9160DK with the HCI UART code and the nRF9160 with the LTE_BLE_Gateway code.
Is this correct?
What should I program the nRF52833 with?
Rod
  • Watts-MacBook-Pro-2:nrf Watt$ west init -m https://github.com/nrfconnect/sdk-nrf --mr v1.3.0
    FATAL ERROR: already initialized in /Users/Watt/zephyrproject, aborting.
    Note:
        In your environment, ZEPHYR_BASE is set to:
        /Users/Watt/zephyrproject/zephyr
        This forces west to search for a workspace there.
        Try unsetting ZEPHYR_BASE and re-running this command.
  • Looks like there is some confusion ongoing. What is /Users/Watt/zephyrproject/? In your environment, ZEPHYR_BASE is set to: /Users/Watt/zephyrproject/zephyr
    Have you tried to initialize NCS inside of a zephyr repo? As the output from your previous comment:
    Watts-MacBook-Pro-2:nrf Watt$ pwd
    /Users/Watt/zephyrproject/ncs/nrf
    NCS is initialized inside of zephyrproject, and this includes another zephyr folder:
    /Users/Watt/zephyrproject/ncs/zephyr
    Please try to fix this first.
    Øyvind
  • Morning Øyvind,
    This is what I have in my /Users/Watt/zephyrproject directory...
                Watts-MacBook-Pro-2:zephyrproject Watt$ pwd
                 Watts-MacBook-Pro-2:zephyrproject Watt$ ls
                             bootloader modules ncs tools zephyr
    Yes, my Zephyr base is set to.
    ZEPHYR_BASE=/Users/Watt/zephyrproject/zephyr
    Under ncs, the only directory is nrf. Its empty.
    I agree, it looks like my directory structure is messed up. I have tried to reinstall, please see my last posting, but this has failed.
    Whats the easiest way to reinstall?
  • Good morning Rod,
    My apologies for the late reply. From your last comment, I agree that something is messed up.
     Try to add a new folder to /Users/Watt/ e.g. NCS. Follow the instructions given here. Inside of /Users/Watt/NCS run the following command in terminal:
    This will clone the manifest repository into NCS. Once complete, run the following commands:
    west update
    west zephyr-export
    Lastly, make sure to install dependencies:
    pip3 install -r zephyr/scripts/requirements.txt
    pip3 install -r nrf/scripts/requirements.txt
    pip3 install -r bootloader/mcuboot/scripts/requirements.txt
    Let me know how that works for you.
    Øyvind
  • Hi Øyvind,
    No problem. I followed your instructions above but still seeing problems.
    atts-MBP-2:lte_ble_gateway Watt$ west build -b nrf9160dk_nrf9160ns
    Including boilerplate (Zephyr base): /Users/Watt/zephyrproject/zephyr/cmake/app/boilerplate.cmake
    -- Application: /Users/Watt/zephyrproject/ncs/nrf/samples/nRF9160/lte_ble_gateway
    -- Zephyr version: 2.3.0-rc2 (/Users/Watt/zephyrproject/zephyr)
    -- Found Python3: /Library/Frameworks/Python.framework/Versions/3.8/bin/python3.8 (found suitable exact version "3.8.1") found components: Interpreter
    -- Board: nrf9160dk_nrf9160ns
    -- Found west: /Library/Frameworks/Python.framework/Versions/3.8/bin/west (found suitable version "0.7.2", minimum required is "0.7.1")
    -- Found dtc: /usr/local/bin/dtc (found suitable version "1.6.0", minimum required is "1.4.6")
    -- Found toolchain: gnuarmemb (/Users/Watt/gnuarmemb)
    -- Found BOARD.dts: /Users/Watt/zephyrproject/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns.dts
    -- Found devicetree overlay: /Users/Watt/zephyrproject/ncs/nrf/samples/nRF9160/lte_ble_gateway/nrf9160dk_nrf9160ns.overlay
    nrf9160dk_nrf9160ns.dts.pre.tmp:92.42-104.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/flash-controller@39000: duplicate unit-address (also used in node /soc/peripheral@40000000/kmu@39000)
    nrf9160dk_nrf9160ns.dts.pre.tmp:201.18-207.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/uart@a000: duplicate unit-address (also used in node /soc/peripheral@40000000/i2c@a000)
      also defined at nrf9160dk_nrf9160ns.dts.pre.tmp:498.8-501.3
      also defined at nrf9160dk_nrf9160ns.dts.pre.tmp:605.8-613.3
    nrf9160dk_nrf9160ns.dts.pre.tmp:341.19-347.3: Warning (unique_unit_address_if_enabled): /soc/peripheral@40000000/clock@5000: duplicate unit-address (also used in node /soc/peripheral@40000000/power@5000)
    -- Generated zephyr.dts: /Users/Watt/zephyrproject/ncs/nrf/samples/nRF9160/lte_ble_gateway/build/zephyr/zephyr.dts
    -- Generated devicetree_unfixed.h: /Users/Watt/zephyrproject/ncs/nrf/samples/nRF9160/lte_ble_gateway/build/zephyr/include/generated/devicetree_unfixed.h
    /Users/Watt/zephyrproject/ncs/nrf/samples/nRF9160/lte_ble_gateway/prj.conf:18: warning: attempt to assign the value 'y' to the undefined symbol LTE_LINK_CONTROL
    /Users/Watt/zephyrproject/ncs/nrf/samples/nRF9160/lte_ble_gateway/prj.conf:19: warning: attempt to assign the value 'n' to the undefined symbol LTE_AUTO_INIT_AND_CONNECT
    /Users/Watt/zephyrproject/ncs/nrf/samples/nRF9160/lte_ble_gateway/prj.conf:22: warning: attempt to assign the value 'y' to the undefined symbol AT_HOST_LIBRARY
    /Users/Watt/zephyrproject/ncs/nrf/samples/nRF9160/lte_ble_gateway/prj.conf:25: warning: attempt to assign the value 'y' to the undefined symbol BSD_LIBRARY
    /Users/Watt/zephyrproject/ncs/nrf/samples/nRF9160/lte_ble_gateway/prj.conf:28: warning: attempt to assign the value 'n' to the undefined symbol BSD_LIBRARY_TRACE_ENABLED
    /Users/Watt/zephyrproject/ncs/nrf/samples/nRF9160/lte_ble_gateway/prj.conf:31: warning: attempt to assign the value 'y' to the undefined symbol NRF_CLOUD
    /Users/Watt/zephyrproject/ncs/nrf/samples/nRF9Parsing /Users/Watt/zephyrproject/ncs/nrf/samples/nRF9160/lte_ble_gateway/Kconfig
    Loaded configuration '/Users/Watt/zephyrproject/zephyr/boards/arm/nrf9160dk_nrf9160/nrf9160dk_nrf9160ns_defconfig'
    Merged configuration '/Users/Watt/zephyrproject/ncs/nrf/samples/nRF9160/lte_ble_gateway/prj.conf'
    160/lte_ble_gateway/prj.conf:45: warning: attempt to assign the value 'y' to the undefined symbol DK_LIBRARY
    /Users/Watt/zephyrproject/ncs/nrf/samples/nRF9160/lte_ble_gateway/prj.conf:46: warning: attempt to assign the value 'n' to the undefined symbol DK_LIBRARY_INVERT_LEDS
    /Users/Watt/zephyrproject/ncs/nrf/samples/nRF9160/lte_ble_gateway/prj.conf:58: warning: attempt to assign the value 'y' to the undefined symbol BT_GATT_DM
    /Users/Watt/zephyrproject/ncs/nrf/samples/nRF9160/lte_ble_gateway/prj.conf:59: warning: attempt to assign the value 'y' to the undefined symbol BT_SCAN
    /Users/Watt/zephyrproject/ncs/nrf/samples/nRF9160/lte_ble_gateway/prj.conf:60: warning: attempt to assign the value 'y' to the undefined symbol BT_SCAN_FILTER_ENABLE
    /Users/Watt/zephyrproject/ncs/nrf/samples/nRF9160/lte_ble_gateway/prj.conf:61: warning: attempt to assign the value '1' to the undefined symbol BT_SCAN_UUID_CNT
    error: Aborting due to Kconfig warnings
    CMake Error at /Users/Watt/zephyrproject/zephyr/cmake/kconfig.cmake:217 (message):
      command failed with return code: 1
      /Users/Watt/zephyrproject/zephyr/cmake/app/boilerplate.cmake:510 (include)
      /Users/Watt/zephyrproject/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:24 (include)
      /Users/Watt/zephyrproject/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:35 (include_boilerplate)
      CMakeLists.txt:20 (find_package)
    FATAL ERROR: command exited with status 1: /usr/local/bin/cmake -DWEST_PYTHON=/Library/Frameworks/Python.framework/Versions/3.8/bin/python3 -B/Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/lte_ble_gateway/build -S/Users/Watt/zephyrproject/ncs/nrf/samples/nrf9160/lte_ble_gateway -GNinja -DBOARD=nrf9160dk_nrf9160ns
    Watts-MBP-2:lte_ble_gateway Watt$
