Test nRF51822 through SWD interface after programming (through RTT?)
After programming a panel of 6 modules embedding nRF51822, I would like to send some data in order to test some features. The basic idea is to validate the modules before cutting it from panel and mounting it in its final case. For example, I would like to light a led, start moving motors, etc...
Because I don't have any unused GPIO to use standard UART to do it, I was wondering if it could be possible to send data catchable by the chip trough SWD interface.
I heard about the J-Link RTT feature and it sounds promising, but it seems only possible to read/write register. My need would be to catch the data sent in the code (like with an UART) to execute behavior in order to test physical mounted pieces like motors.
Is it a way to send data to nRF51822 through SWD interface like UART?
Edit
The target of this test is to validate that complex component are well mounted on the PCB. It needs several little screw to make contact on the PCB and is a sensible part of the module. Of course, it is not as simple as toggle a GPIO to test this component because a specific frequency must be generated to test it, so I need to send command to the module to run the test.
