nrf_pwr_mgmt_run() with SoftDevice not go to low power
Hello.
I use SDK16 in my project.
Previously when I want to go on sleep I use __WFI(), and get into sleep till interrupt. Because I use The SoftDevice I change the command to nrf_pwr_mgmt_run() as instruct by Nordic . But now it doesn't enter sleep at all. I try also disable the FPU by NRF_PWR_MGMT_CONFIG_FPU_SUPPORT_ENABLED 0 in the sdk_config.h but didn't help.
Why it is so?
Bar.
  • Hello Jared.
    As  I look into sd_app_evt_wait() I just get to this function
    SVCALL(SD_APP_EVT_WAIT, uint32_t, sd_app_evt_wait(void));
    But can't get inside. It is look it send and receive interrupt flags from the SD.
    I look on the header explain and I see this:
    In order to wake up from disabled interrupts, the SEVONPEND flag has to be set in the Cortex-M
    MCU's System Control Register (SCR), CMSIS_SCB.
    ... The application must ensure that the pended flag is cleared using ::sd_nvic_ClearPendingIRQ
     in order to sleep using this function. This is only necessary for disabled interrupts
    I can't find anything about sd_nvic_ClearPendingIRQ
    But when look for the SEVONPEND flag I found this discussion: https://devzone.nordicsemi.com/f/nordic-q-a/7107/sevonpend-setting---how-to
    WHere he did some work exactly with the some function I try to handle.
    Where look for https://devzone.nordicsemi.com/f/nordic-q-a/7107/sevonpend-setting---how-to
    So I look for SCB_SCR_SEVONPEND_Msk and the only thing I found was
    SCB->SCR |= SCB_SCR_SEVONPEND_Msk;
    which is close by #ifdef PWR_MGMT_SLEEP_IN_CRITICAL_SECTION_REQUIRED
    DO I need to open this define?
    I also read comment exactly about some issue with sd_app_evt_wait(void) and excessive current. They all take about the FPU and its interrupt panding. https://devzone.nordicsemi.com/f/nordic-q-a/13670/solved-nrf52-sd_app_evt_wait-will-not-go-to-sleep
    But I try some like
      // Set bit 7 and bits 4..0 in the mask to one (0x ...00 1001 1111)
      #define FPU_EXCEPTION_MASK 0x0000009F
          /* Clear exceptions and PendingIRQ from the FPU unit */
          __set_FPSCR(__get_FPSCR()  & ~(FPU_EXCEPTION_MASK));
          (void) __get_FPSCR();
          NVIC_ClearPendingIRQ(FPU_IRQn);
    before
    error_code = sd_app_evt_wait();
    but didn't help.
    What could be the problem?
    Regards
    Bar.
  • Hi Jared.
    I found also something strange about implement the _WFE()
    In some examples I found it set like this
    __WFE();
    __SEV();
    __WFE();
    but using it won't get it to low power
    But know during reading about sd_app_evt_wait();
    I found it is written like this
    __SEV();
    __WFE();
    __WFE();
    This one work.
    So maybe inside  sd_app_evt_wait();
    It still use the wrong setting
    __WFE();
    __SEV();
    __WFE();
    (I can't look inside this function at my SDK)?
    Bar.
    Thank you for your observations.
    Could you upload a minimal project that reproduces the issue and will run on the nRF52840 DK? I'll try to reproduce it and see if I can find the root cause.
    best regards
    Jared
